975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profiles and a Ti spindle!
Author Topic: Profiles and a Ti spindle!  (Read 574 times)
Sean 2000
« on: July 05, 2008, 08:09 PM »
Ive just regreased my cranks and fitted a ti spindle and flush mount kit.
When i put the arms back on i didnt even need the special tool to get them on the spindle, they just pushed on!! Does this sound right?
They were a lot tighter fitting with the cromo spindle.
Help, i plan to start riding again on wednesday (after a broken leg) so obviously i want the bike to be spot on.  :shocked:
Cheers peeps
Sean.
Re: Profiles and a Ti spindle!
« Reply #1 on: July 05, 2008, 08:33 PM »
ive had this with me cromo just fell on
but ti spindle was a bit tighter
just put some more grease on and do it up tight
Sean 2000
« Reply #2 on: July 05, 2008, 11:20 PM »
Yeh but is it SAFE Rhys?  :-\
« Reply #3 on: July 05, 2008, 11:58 PM »
never had any probs so far mate
Lazarou
« Reply #4 on: July 06, 2008, 01:08 AM »
How old are the arms? They do get slightly easier over time.
Sean 2000
« Reply #5 on: July 06, 2008, 05:56 PM »
Hmmm, they aint new i know that much!
I'm just concerned about there integrity, dont want the spindle or arms shearing on me mid run.
Dont know wether to put the cromo spindle back in as that fitted very snuggly?
Help  :-\
Lazarou
« Reply #6 on: July 06, 2008, 06:03 PM »
Well if it's any consolation i've seen the bosses at either end snap many times, i've also seen them snap halfway up the arm but i've never seen the splines shear off!!
« Reply #7 on: July 06, 2008, 06:12 PM »
I got some well used profiles with Ti axle off mcnulty about a year ago and thay had the same senario-loose ish arms and no tool required to install, they are finer than a fine thing , I used Ti flush bolts for a while but they were shit as they kept coming undone (could be Ti on Ti combined with looser arm splines  :-\) . Even superglue didn't hold em in  :LolLolLolLol: swapped back to cromo flush bolts and all is well and has been since. Deffo no issues relating to the loose fit when installing though. Hope this helps  :daumenhoch:
Sean 2000
« Reply #8 on: July 06, 2008, 07:30 PM »
Cheers Diggler, thats wot i wanted to hear now!  :daumenhoch:
Sean.
