975755
TattooedYorkie
September 22, 2024, 06:23 PM
any tips on fitting tyres?
Topic: any tips on fitting tyres? (Read 612 times)
Paolo89
July 05, 2008, 11:46 AM »
Ive got two cheng shin tyres to go on simplex wheels, Finding it a real struggle. Any hints or tips? cheers
Bigfrawg
Flip-Whip
Re: any tips on fitting tyres?
July 05, 2008, 12:33 PM »
LUBRICATION , tis the answer to many a problem!
spesh
heat the wheels up till they go all gooey and then slip the tyres on...........simple
and the put your gooey sh1t wheels on your sh1t burner!!!
not really just lube the tyres up with washing up liquid and they should just slip on
July 05, 2008, 10:38 PM »
make sure the part of the tire you have got on the rim is sat right down in the troff of the rim (where the spoke holes are). This should give you the 'slack' to get the rest of the tire on.
thecrooch
July 05, 2008, 11:08 PM »
all of the above plus try starting at the opposite point of valve..
oh and Park tools tyre levers (the blue ones) - best there is....
