975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 03:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  An alternative to smacking headsets into show bikes with a hammer (pics)
Author Topic: An alternative to smacking headsets into show bikes with a hammer (pics)  (Read 1672 times)
Jazzchimp
Came up with a solution today to fitting the old headsets to show bikes as a substitute for a headset press, which I don’t have.
I got a piece of all-thread, a block of wood for the bottom, a washer for the top (which just fits into the cup) and a socket.
Tightened up the nuts (no need to overtighten) and tapped the cup, then tightened and tapped and so on. Kept on till it was home. Popped in a treat and never touched the paint.
I was so chuffed with myself  :laugh:
Told you guys I was anal!!
where did you get the threaded bar from.
Offline ORB
the threaded bar shop.
12
you would think i would learn by now would'nt you  :crazy2:.
Offline danny silverstreak
Theres you messing about with bmx bikes and there is a basket full of ironing to do there jazz :wtf: :LolLolLolLol:
I have been using this method for years Jazz, it is better than hitting it with a hammer though.
Bren Gunn
Builders merchant for the threaded bar... try Travis Perkins, they sold it when I worked for them last year ;)
cheers bren a sencible answer for a change  :daumenhoch:
Offline Nosnod
Loving that full padset.. is it a cal-lite?!!!  ; ;) ;D
Offline Dingobmxer
Hmmmm black Ripper per chance???????????????????????
 :) DINGO :)
Threaded bar from any engineers supplies shop.  Another alternative is a 6" bench vice which you can use as a press. Just make sure jaw faces are fitted with some protection so as not to damage yer cups....
Personally,  I use a hydraulic press. Job's a good 'un  :daumenhoch:
Jazzchimp
Padding is another of my hot tips for maximum protection.
All-thread is available from most building merchants like Bren says.
