975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 18, 2024, 04:12 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Advice required REDLINE FLIGHT CRANKSET
Author Topic: Advice required REDLINE FLIGHT CRANKSET  (Read 1107 times)
adam01
« on: June 26, 2008, 09:43 AM »
Hi all
i have the Aero Reflex will the   REDLINE FLIGHT CRANKSET Chrome 180mm fit my frameset ?!!!
REDLINE FLIGHT CRANKSET Chrome 180mm american bb bmx
DUEL PINCH BOLT DESIGN.
WRAPPED AND WELDED PEDAL BOSSES.
RIGHT SIDE DRIVE.
19MMX6T HEAT-TREATED CHROMOLY SPINDLE.
SPINDLE BOLTS AND SPROCKET BOLT INCLUDED.
RH: 11.48 OUNCES (325G) / LH: 10.79 OUNCES (306G)
REDLINE FLIGHT CRANKS WITH DOUBLE PINCHBOLTS
SEALED AMERICAN STYLE BB
COMPLETE SET
cheers need to know before i buy them
adam
« Last Edit: June 26, 2008, 10:48 AM by adam01 »
Re: Advice required REDLINE FLIGHT CRANKSET
« Reply #1 on: June 26, 2008, 09:45 AM »
Think they will fit Adam? JT71 (joe) may know more about this as he has a ton of Reflex's  :daumenhoch:
adam01
« Reply #2 on: June 26, 2008, 09:47 AM »
thanks for quick reply much appreciated i will wait around until he turns up
Adam  :daumenhoch:
« Reply #3 on: June 26, 2008, 09:53 AM »
should fit just fine!  the Reflex frame (in fact i'd say 99%) old school bikes have a US BB shell so it should go in fine  :daumenhoch:
adam01
« Reply #4 on: June 26, 2008, 09:55 AM »
thats brilliant news thanks guys for the advice as always very much appreciated
AD
dannywhiteley
« Reply #5 on: June 26, 2008, 10:47 AM »
I would agree.  It will fit.
Frosty
« Reply #6 on: June 26, 2008, 10:56 AM »
just need to watch out for the length of some arms on some frames as they can run very close to the chainstays - but spacers can sort this worth a watch though.
« Reply #7 on: June 26, 2008, 11:29 AM »
Fits most things old school fella  :daumenhoch:
They are nice and smooth too  :coolsmiley:
http://s58.photobucket.com/albums/g243/gashead69/?action=view&current=ProExp004.jpg
http://s58.photobucket.com/albums/g243/gashead69/?action=view&current=kuwidayout006.jpg
Give us a shout if you need a hand on how to fit  :daumenhoch:
Nick :daumenhoch:
Frosty
« Reply #8 on: June 26, 2008, 01:15 PM »
Here's some on a hauler, the drive side is a tad closer too.
« Reply #9 on: June 26, 2008, 01:30 PM »
those arent double pinch though....
adam01
« Reply #10 on: June 26, 2008, 02:49 PM »
looking excellent
always loved redline flights . just have to find a CHAINWHEEL to fit it ?!!!
Adam
Frosty
« Reply #11 on: June 26, 2008, 02:56 PM »
Good point Mr Fruit, I assumed that the double pinchers ran similar specs but maybe not then!
adam01
« Reply #12 on: June 26, 2008, 03:02 PM »
got me worried now whats all that about double pincher's  :knuppel2:
AD
PS: will my pedals fit the redline flights
« Last Edit: June 26, 2008, 03:50 PM by adam01 »
dannywhiteley
« Reply #13 on: June 26, 2008, 04:11 PM »
Look at where the pedal screws into the crank arm, see those two bolts on Gasheads Curtis, they are twin pinch.  Frostys only has one bolt so is single pinch.  Twin pinch are new; single (and pinchless) are older (and thus more expensive).
With pedal fitting, as long as your pedals are 9/16 thread (for 3 piece cranks) and not 1/2 thread (1 piece) then you are ok.
dannywhiteley
« Reply #14 on: June 26, 2008, 04:12 PM »
I fitted some twin pinch to my T/A (travesty... :) ) and they went on a treat, look fabulous darling, and dont cost the earth.
adam01
« Reply #15 on: June 26, 2008, 04:19 PM »
this is my set up at moment obversely its all coming off the aero reflex , looks like i will also need new os pedals then for the redline flights
« Last Edit: June 26, 2008, 04:51 PM by adam01 »
dannywhiteley
« Reply #16 on: June 26, 2008, 04:44 PM »
Yes, you wont be able to use those pedals with the flights.
« Reply #17 on: June 26, 2008, 05:14 PM »
Love these cranks, want a set for my OS bike  :smitten:
adam01
« Reply #18 on: June 26, 2008, 10:51 PM »
forgot to ask will Landing Gear forks fit me AERO REFLEX
AD
« Reply #19 on: June 26, 2008, 11:28 PM »
The cranks will fit just fine.  Space as required to clear the frame.  You need pedals with 9/16" axles, your current one piece crank pedals have 1/2" axles....
All conventional 1" threaded headset forks will fit your frame  :)
adam01
« Reply #20 on: June 27, 2008, 12:13 AM »
as always much appreciated in all your helps guys
Adam
