975755
TattooedYorkie
September 24, 2024, 06:17 AM
hollow stem bolts
Topic: hollow stem bolts (Read 638 times)
stevo70
hollow stem bolts
June 25, 2008, 08:44 PM »
can a tuff neck stem have a hollow stem bolt if so where can i get one? If thats not possible what is the best old skool stem to use that can take a hollow stem bolt?
cheers guys
Stephen
adeshere
Re: hollow stem bolts
June 25, 2008, 10:23 PM »
They should all be able to take a hollow stem bolt .
You might need a washer under the nut if the hole is too large
they usually came with a wedge on the bottom already
hollow stem bolts
