975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:13 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP PLEASE!! SHAKY TUFF 2
Author Topic: HELP PLEASE!! SHAKY TUFF 2  (Read 1391 times)
d14vd_h
« on: January 06, 2006, 06:35 PM »
my brother recently replcaed his chain on his gold supertuff burner.
in manhandling the wheel the axle seems to have come loose!
he says that it was slightly shaky beforehand but it seems to have worsened since this.
we got the bikes in december.
the wheels now shakes side to side on the axle. not a huge amount but noticeably so and enough to make riding difficult!
is the wheel a right off? can it be tightened or does the axle/bearings/hub need replaced!?
help please.
thanks in adavance.
« Last Edit: January 06, 2006, 06:37 PM by d14vd_h »
Offline Rombloke
  • do one
Re: HELP PLEASE!! SHAKY TUFF 2
« Reply #1 on: January 06, 2006, 06:39 PM »
losen the axle nuts that hold the wheel to the frame.....then using a cone spanner, tighten the cone nuts(these are on the inside of the dropout) until the wobbly spindle is cured, but leaving it loose enough that the wheel spins freely.
so no its not a write-off jusy a case of fiddling with ya nuts...ooeer missus
Dave
haro, how do you do
d14vd_h
« Reply #2 on: January 06, 2006, 06:44 PM »
ok now that my fear is put aside any cahnce u can put that in dumb terms.
in pretty new to the scene so i dont have a cone spanner i dont think!?
i have taken the wheel completley off the frame, and the wheel moves from side to side on the axle,
tools at hand are a bike tool with all shapes of nut cutouts, and 2 barbell style tools for various nut sizes.
i was initially frightened as a raleighigh mag colapsed at the axle underneath me once and it was a write off! thanks for your reply!
if u can gimme a run thru i'll do it tonight.
« Reply #3 on: January 06, 2006, 06:59 PM »
well come on then dave  :LolLolLolLol:.
currio
« Reply #4 on: January 06, 2006, 07:09 PM »
Barbell style tools ?
The wheel collapsed ?
 :wtf:
Offline Rombloke
  • do one
« Reply #5 on: January 06, 2006, 07:10 PM »
ok easy.......there should be two thin nuts nearest to the hub on both sides of the wheel...plus the two axle nuts that attach the wheel to the frame.
you need to tighten the two thin nuts on one side of the hub. this is done by undoing the outer one, which acts as a lock nut.....then tighten the inner one towards the hub itself...then retighten the lock nut and re-fit the wheel.
have i made that simple or hard i cant tell.
hope ive helped and not confused you fella
Dave
haro, how do you do
Offline Waxintaxin
« Reply #6 on: January 06, 2006, 07:33 PM »
You are going to need some more tools for sure . I would take it to a bike shop its going to be cheaper than a full tool kit :)
Cone tightening is not a big job and should only be a couple of quid , but riding it will indeed kill it untill you get it sorted :)
I havent seen a multi dumbell spanner for fkin ages lol
Rich :)
d14vd_h
« Reply #7 on: January 06, 2006, 08:06 PM »
right dave sounds like i can manage it,
thanks so much for the info and the speed of the reply.,
its do able with the tools i have?
if i encounter probs i'll take some pics to help the process.
let u know
thanks a lot!!!! :santa_afro:
Offline Rombloke
  • do one
« Reply #8 on: January 06, 2006, 09:31 PM »
no worries mate....just take your time bloke and you will manage it. like rich says dont ride it till youve fixed it tho mate..
good luck
Dave
haro, how do you do
Offline ORB
« Reply #9 on: January 06, 2006, 09:34 PM »
Quote
I keep buying bike spanners at auto jumbles.
The most handy things by far!
12
weston
« Reply #10 on: January 06, 2006, 09:38 PM »
theres a how to fix bikes website with step by step pics... i'll find the link
d14vd_h
« Reply #11 on: January 08, 2006, 02:35 PM »
its fixed :daumenhoch: cheers guys!!!
theres a slight clunky sound comes form the back wheel when it turns any ideas? doesnt seem to be any interference with th running of the wheel tho.
ps i hate chain tensioners!
« Reply #12 on: January 09, 2006, 03:42 PM »
could be that the bearings are now a bit worn, due to the loosness of the nuts before.
is it when you pedal, or when it is freewheeling?
