975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 11:40 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline twin pinch crank - fitting instructions???
Author Topic: Redline twin pinch crank - fitting instructions???  (Read 822 times)
« on: May 31, 2008, 05:15 PM »
Ok gonna go with the twin pinch for my GT now as it seems I have loads missing on my proline cranks I bought  :( :knuppel2:
So what's the best way of getting the cups into the bottom bracket without fooking them up or scratching them? Don't want to use a hammer as I think i'll chip them so advice needed please.
Ta,
Matt  :daumenhoch:
Re: Redline twin pinch crank - fitting instructions???
« Reply #1 on: May 31, 2008, 05:40 PM »
i have a 30 or 32mm socket i use i will be at rom tomorow if ya wanna borrow it matt
it sits on the bearing so doesnt damage the alloy cups
« Reply #2 on: May 31, 2008, 05:43 PM »
Can't pop over tomorrow Rhys but thanks anyway, gotta work  :(
How do you get the cups in? Is it via a vice or some other method?
Thanks,
Matt  :)
« Reply #3 on: May 31, 2008, 05:54 PM »
i just tap em in with a hammer and me socket
« Reply #4 on: May 31, 2008, 05:58 PM »
What time are you over there mate tomorrow Rhys? May try and pop over but can't 100% guarantee. Will let you know later if I can get some of this work out of the way  ;)
« Reply #5 on: May 31, 2008, 06:08 PM »
10 till 2 mate
steve Beech TA
« Reply #6 on: May 31, 2008, 06:27 PM »
Hi matt,
I put grease around the  bearing cup insert, then hold the frame level and square on its side on the floor then use a rubber mallet to tap the bearing cup in, just make sure the bearing cup is even as you knock it in. if you have not got a rubber mallet then a piece of wood will do the same thing, although it may be a bit awkward.
hope this helps
Cheers steve :daumenhoch:
Offline Gary72
« Reply #7 on: May 31, 2008, 06:30 PM »
Depends on how well they fit, have had to use the vice at work with 2 plates of metal and some foam on 1 set of cups. And on my Robinson just a pair of quick clamps done the job, same with bearings into cups I have one that pushes in by hand and the other needs some help from the hammer. Might go to rOm tommorow(just got back,(the wifes camping)), if you dont make it and I see Rhys, I'll pick up his tool and get Caroline to drop it off as she only works round the corner to you Matt.
« Reply #8 on: May 31, 2008, 06:31 PM »
I do have a rubber mallet actually steve! If that will do it and not damage it that'll be superb, thanks mate for that  :daumenhoch:
« Reply #9 on: May 31, 2008, 06:32 PM »
Gary hi mate. Me and Lucie will try and pop over to Rom tomorrow about 11:30. Ain't been to Rom in years and years, so any pointers of how to get there once in Romford?
Ta,
Matt  :daumenhoch:
« Reply #10 on: May 31, 2008, 06:38 PM »
upper rainham rd i think it is pull into the total garage and go left thru gates
Offline Gary72
« Reply #11 on: May 31, 2008, 06:45 PM »
