975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 12:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxalic Acid Solution Strength?
Author Topic: Oxalic Acid Solution Strength?  (Read 556 times)
Offline Bigplinky
« on: May 28, 2008, 10:16 PM »
Just got some oxalic acid for a bit of rust off action but I have no idea what strength of solution to mix up, can anybody give me some advice please  :)
FuNMoNsTeR
Re: Oxalic Acid Solution Strength?
« Reply #1 on: May 29, 2008, 04:15 PM »
bmx xxx
« Reply #2 on: May 29, 2008, 04:35 PM »
if i remeber right i put 5kilos of crystals into a plasters bath and filled it up just over the frame, with the frame laying on its side,
tell you this stuff is sweet on rust, looks like a diffent bike when you get it out, :daumenhoch:
good luck and i also disovles bodies too.
Offline Bigplinky
« Reply #3 on: May 29, 2008, 04:37 PM »
Cheers Andy  :daumenhoch: couldn't find the threads when I looked last night
Should be at MK this year but I'm so unfit I'll only be racing to turn 2 and coasting the rest  :LolLolLolLol:
Cheers BMX XXX only bought 500g as a bit of a toe in the water tester  :D
bmx xxx
« Reply #4 on: May 29, 2008, 04:39 PM »
500g will be good for handlebars or stem etc, but not for frames,
all the best gary
