975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 02:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  10mm wheels into 14mm dropouts?
Author Topic: 10mm wheels into 14mm dropouts?  (Read 1155 times)
scary_leary
« on: January 03, 2006, 06:42 PM »
Whats the easiest way to put 10mm wheels into 14mm drops....please?
Sanmarcopizza
Re: 10mm wheels into 14mm dropouts?
« Reply #1 on: January 03, 2006, 06:48 PM »
The easiest way is to buy some top hat washers. About a fiver a pair. If you need to run pegs then you need some Primo Andy's nuts (£12 pair) in the long length, or you can use regular length to just convert from 10 to 14mm.
scary_leary
« Reply #2 on: January 03, 2006, 06:59 PM »
Cheers San
see ya at bones  :santa_afro:
Offline Dingobmxer
« Reply #3 on: January 04, 2006, 07:29 AM »
or buy some of those chaintensioners that have two holes,Odyssey Pact they are called
 :) DINGO :)
HEYWOOD BMX
« Reply #4 on: January 04, 2006, 11:44 AM »
 :) Most pegs are designed for 14mm axles,but come with a 10mm adaptor inside each peg.These work fine as a converter for 10mm to 14mm.
Offline Rombloke
  • do one
« Reply #5 on: January 04, 2006, 04:01 PM »
but then youll need converters for the pegs.....lol
i'll get my coat!!!
Dave
haro, how do you do
Sanmarcopizza
« Reply #6 on: January 04, 2006, 04:10 PM »
Daves laughing but it's the truth. I had the same problem on my red Kappa. Front & Back 14mm drop outs, front & back 10mm axles. Initially I was gonna use a set of pegs I had, one 10mm & one 14mm and no adapters. When I was looking before Chrimble no one had long Promo Andys nuts, so I got some short ones. The thought then hit me that they wouldn''t be long enough to pass through both the peg & dropout. I then found some Hoffman pegs that were light and thin and found that the short Andy's nut does actually do the job.
I you aint running pegs, you don't have such problems.
