975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 09:57 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Ody Cassette Change HOW?
Author Topic: Ody Cassette Change HOW?  (Read 1856 times)
JT71
« on: May 11, 2008, 07:57 PM »
anyone tell me how to change the cog on an Ody cassette hub?
any help greatly appreciated
kind regards Joe
Offline Philbert
Re: Ody Cassette Change HOW?
« Reply #1 on: May 11, 2008, 08:01 PM »
piece of piss dude!
take the lock ring off from the side. just unscrew it with big spanner
then the cog just slides off! (from what i can remember)
« Reply #2 on: May 11, 2008, 08:05 PM »
Just like Phil says. Its real easy.
Undo the cone nuts (maybe its just one?) on the cog side, and then the cog and the ratchet things (I forget the name of them) will just pull away from the hub. Even undoing the cone nuts is easy cos you can hold the spindle by using an allen key in the hex hole in the end.
JT71
« Reply #3 on: May 11, 2008, 08:05 PM »
piece of piss dude!
cheers phil, that's what i thought. but does it undo the wrong way? cos the usual way the cog turns, if you see what i mean.
« Reply #4 on: May 11, 2008, 08:08 PM »
The cog dont turn (its not held on by any threads), it just pulls away from the hub once the cone nut is off  :daumenhoch:
Offline Philbert
« Reply #5 on: May 11, 2008, 08:10 PM »
fook! can't remember that bit.
the cogs not threaded only the lock ring
its internationally recognised that a normal threading nut will have smooth edges and a reverse thread nut will have notches in it! failing that bring it tomorrow night and i'll show you!
« Reply #6 on: May 11, 2008, 08:12 PM »
Cool, I never knew that. Nice one Phil.
« Reply #7 on: May 11, 2008, 08:24 PM »
unless its a one piece driver
« Reply #8 on: May 11, 2008, 08:30 PM »
Oh yes. Sorry. Ive only ever used/swapped a one piece driver. I forgot there was another type.  :-\
JT71
« Reply #9 on: May 11, 2008, 08:35 PM »
sorted now chaps, but made a mess of the lock ring as I over tightened it trying to get it off the wrong way.
grrrrrrrrrrrrrrrrrrr. lesson learned: ask before fokking with it.
it'll still work, just looks a bit shit.
JT71
« Reply #10 on: May 11, 2008, 08:35 PM »
and thanks chaps, legends.  :daumenhoch:
