0 Members and 6 Guests are viewing this topic.
Complete, virtually un-used Coyote Acid Skull here.it's moley's if he want's it, but I supsect Phil's got better bits and frame.so...how about if I drop it off at Phils and he takes what he needs from it?
yeah i thought your frame would be a better model Phil, so if you just use the bits you don't have off JT's bike? then Moley would have a ride again?? so lets have a few donations to Phil then to cover postage and a pint or two for his troubles
Quote from: pickle on May 11, 2008, 07:36 PMyeah i thought your frame would be a better model Phil, so if you just use the bits you don't have off JT's bike? then Moley would have a ride again?? so lets have a few donations to Phil then to cover postage and a pint or two for his troubles bit of luck may have enough left over so he can buy a razor too
the acid skull is the lesser specced bike from coyote with only hi tensile steel used!i'm offering my coyote schizoid frame, forks, wheels, etc which is full chromoly and exactly what moley was riding!like i said i'm not asking for money for the parts, just donations to get moley back on something he's become used too!
Quote from: QUADROPHENIA on May 11, 2008, 07:53 PMQuote from: pickle on May 11, 2008, 07:36 PMyeah i thought your frame would be a better model Phil, so if you just use the bits you don't have off JT's bike? then Moley would have a ride again?? so lets have a few donations to Phil then to cover postage and a pint or two for his troubles bit of luck may have enough left over so he can buy a razor tooits already gone pete! went when i got in. only did it to try and fit in with all the old people!
