975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 11:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How to remove a one piece crank???
Author Topic: How to remove a one piece crank???  (Read 577 times)
sparky1975
« on: May 06, 2008, 09:27 PM »
Any hints, tips or how to's... need to remove and re grease... but still need my knuckles ???
THANKS,
             Mark ;)
Fashionrider
Re: How to remove a one piece crank???
« Reply #1 on: May 06, 2008, 09:41 PM »
THANKS,
             Mark ;)
hey dude its been a while butttt
i think theres a main threaded spacer (on the opposite side to the disk) supporting the whole crank, if my memory serves me its like a 26mm/28mm size, once this is unthreaded the cranks will become lose... then pretty much take all the spacers off (and the pedal of course) and slide the crank out.
make sure your chain is removed before you do this
sorry if its wrong, im a youngun and been running 3 peice for the last 5 years
cheers
adeshere
« Reply #2 on: May 06, 2008, 11:38 PM »
First remove the pedal on the non-chainwheel side.
On this side you will find a large nut.
Undo this ... ITS A LEFT HAND THREAD !!
then there might be a washer and then there is a large washer looking bit with two slots cut in too it. use a screwdriver to knock it clockwise to unscrew it.
You can then pull the crank out from the other side.
sparky1975
« Reply #3 on: May 07, 2008, 01:32 PM »
Aaahhh! I see now... left handed thread.... thats why the bugger wasnt for coming off and explains why the crank came harder to turn too.... Thanks guys... ;D :shocked:
Feel a bit daft now :-[ :crazy2:
Cheers,
           Mark.
« Reply #4 on: May 07, 2008, 02:47 PM »
i wouldn't feel too bad mate................we've all done it!   :LolLolLolLol:
