976208 Posts in 138989 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 25, 2026, 12:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stripped screw, changings grips, and replacing chain HELP!
Author Topic: Stripped screw, changings grips, and replacing chain HELP!  (Read 1502 times)
humby_14
The screw for my seat post clamp is so rediculously tight that I stripped the screw.  What do I do to get the screw out?
What is the best way to get your grips off on put new ones on so they will not move around on you?
I bought a new chain and want to take the old one off - the old one has a safety clip and the new one doesn't, just a little bolt.  Is this safe or normal? What's the easiest way to change a chain?
Thanks for all your help!!
Offline Rombloke
  • do one
Re: Stripped screw, changings grips, and replacing chain HELP!
« Reply #1 on: May 06, 2008, 06:48 PM »
drill the allen bolt out of you seat clamp.
i always blow grips off of bars with my air line, but a thin screwdriver and some wd40 will work fine....or the best way...cut em off
you can get a link extractor from your local bike shop for a few quid, and they will also sell you a split link if you need it.
ok??
Dave
haro, how do you do
« Reply #2 on: May 07, 2008, 12:29 PM »
putting grips on, ye need to make sure the bars are completely grease free and i spray hairspray into the grips n just slide em on, next day grips are stuck tight and easy to get off, when need be, using rom blokes non airline method :daumenhoch:
« Reply #3 on: May 07, 2008, 01:11 PM »
Who the fook has hair spray in their house?  :laugh:
Offline kdw712
« Reply #4 on: May 07, 2008, 01:28 PM »
certainly not you Bob  :LolLolLolLol:   >:D
last time i fitted some grips i used a bit of lynx deordrant - it did a grand job and smelt nice for 3 days as well  ;D
cheers Kev
« Reply #5 on: May 07, 2008, 03:23 PM »
its to control unsightly chest hairs and create a nice parting between me moobs with a moulded DA towards the crab ladder area, stops me medallion from flipping to the tails side, gotta make the effort once in a while :daumenhoch:
