975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 02:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  white alloy hubbed skyways
Author Topic: white alloy hubbed skyways  (Read 1224 times)
Offline stfc
« on: May 02, 2008, 09:22 PM »
on to a resto of a pair of white tuff 2s now,the 1st picture still shows some evidence of brake rub after 1/2 hr with 800 grade wet and dry, the wheels were refinished by some fool in a rather nice shade of Ford diamond white, this was removed by rubbing down for 2 hrs and 2 dips in the dishwasher on a 65 deg  cycle, the hubs were also concaved from massive overtightening , this has now been pushed back out so all rivets are 99.9% level, the second pic shows the wheels as they are now before (time allowing ) being bleached over the weekend...
Re: white alloy hubbed skyways
« Reply #1 on: May 02, 2008, 09:43 PM »
Coming on well - how did you push the hubs back into shape?
steve Beech TA
« Reply #2 on: May 02, 2008, 09:49 PM »
nice, bet that took a while :daumenhoch:
Offline poolysheriff
« Reply #3 on: May 02, 2008, 10:24 PM »
I got some white tuffs hopefully going in for a bleach bath at the weekend also  :daumenhoch:
Offline stfc
« Reply #4 on: May 02, 2008, 10:32 PM »
self made press, using a 1/2 inch drive bar, vice, padding etc..... and it worked :shocked:
virtualmeuk
« Reply #5 on: May 02, 2008, 11:14 PM »
would like to see a picture of the contraption used to pull the hub out :daumenhoch:
Offline Glynnyboy
« Reply #6 on: May 09, 2008, 01:26 PM »
me too please. :daumenhoch:
2020mad
« Reply #7 on: May 09, 2008, 01:28 PM »
and me i got a few to do.  :daumenhoch:
Offline Steve P
« Reply #8 on: May 18, 2008, 11:45 AM »
Here's a set I restored ... the bleaching/cleaning process is a long job and well worth the extra effort in the end  :daumenhoch:
Steve
« Reply #9 on: May 18, 2008, 12:05 PM »
They all look great, nice work  :)
I'v got a few pairs I'm working on at the mo, giving them a good scrubbing  >:D  Can someone please explain the best way to cover the hubs as I fooked one up last time I put a pair in bleach  :'(
Offline Steve P
« Reply #10 on: May 18, 2008, 12:10 PM »
Chris, I used petroleum jelly which is water-proof ... use a brush to coat the inner hubs too  :daumenhoch:
Steve
« Reply #11 on: May 18, 2008, 12:13 PM »
Thanks Steve, I shall give it a go  :daumenhoch:
Those Tuffs look like new  :shocked:
motomagII
« Reply #12 on: May 20, 2008, 04:26 PM »
bit wet and dry and polish that alloy hub will be as good as new
ozone
« Reply #13 on: June 01, 2008, 10:15 AM »
If you're not too fussed about having bolt-on hubs, you can drill out the rivets, remove the flanges, then put them back in the wheel with the bearing retainers etc facing each other (back to front).  Use the old rivets to hold the flanges in place, then take your axle and slide it through both sets of flanges and carefully tighten the nuts up.  This will pull the hubs back to their original shape.  Take your time but if you do go a little too far you can always flip them the right way round and reverse the process.   Get yourself some replacement bolts and you're sorted.  If you can't find a long enough bolt threaded bar/locknuts works equally well...
If you can't bear bolt-on hubs, go for the home-made press option...
