975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 25, 2024, 10:51 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Headset question Internal/Intergrated NOW WITH USEFUL LINK
Author Topic: Headset question Internal/Intergrated NOW WITH USEFUL LINK  (Read 1774 times)
Offline Gary72
Is there a difference, if so what is it, mine seems to have developed some play, only way to get rid of the play is to tighten the stem down really tight, then the bars are hard to turn??????
Think I need a new headset, just want to make sure I get the right one???
Gary
Problem solved fitted new headset tonight, had a ride up the chippy and all is well. FSA Impact
More headset details here
http://www.fsaprobmx.com/fly.aspx?&languageid=1
« Last Edit: May 02, 2008, 08:32 PM by Gary72 »
Re: Headset question Internal/Intergrated
« Reply #1 on: April 28, 2008, 08:04 AM »
Gary it does sound like you may need new headset, or at least bearings?
what frame is it on?  i think most new frames are internal and run a 45/45 headset (campagno or whatever its called) and are about £20
how old is your current one as they should last at least a few years.....
zed4130
« Reply #2 on: April 28, 2008, 08:08 AM »
FSA make some nice Hsets, campagnolo coas a bomb, but go on for ever,  :smitten:  i find these internal jobs great, and once set , ive never had to adjust them, i think most have roller bearings , nice and smooth, plus even load  :daumenhoch: check out FSA mate,
« Reply #3 on: April 28, 2008, 08:23 AM »
yep have to agree you can't beat the FSA ones for cost and reliability  :daumenhoch:
darkersomeday
« Reply #4 on: April 28, 2008, 08:26 AM »
the integrated headset uses 45deg  angular contact bearing races that sit inside the headtube,
the internal headset is similar but still uses an actual "cup" that presses into the headtube,
most modern bmx frames use the integrated (campagnolo) system :daumenhoch:
hope that helps!
evamedia
« Reply #5 on: April 28, 2008, 10:05 AM »
Not all integrated use 45deg, Eastern and Stolen use 36deg (maybe others)
zed4130
« Reply #6 on: April 28, 2008, 10:13 AM »
when did bmx's become so complecated  :-\
evamedia
« Reply #7 on: April 28, 2008, 10:22 AM »
The late 90's , started with 1 1/8" threadless forks and snowballed from there
zed4130
« Reply #8 on: April 28, 2008, 10:42 AM »
sadly mtb's didnt help, i like basic machines, none of this number mumbo jumbo   ;)
HEYWOOD BMX
« Reply #9 on: April 28, 2008, 10:57 AM »
 :) Did Volume also go with a "different" internal headset as some point as well???
Offline Gary72
« Reply #10 on: April 28, 2008, 11:47 AM »
The frame is a Federal T-Nez, only had for a year. But I think this is my fault, tried to raise the bars by adding a spacer and I think I over tightened it :-[
Sounds like it's intergrated as there is no seperate cups, Think I will get onto Mr.Bar Ends (Trev) the Fly ones look nice.
Thanks for the help and advice
Gary
« Reply #11 on: April 28, 2008, 11:49 AM »
the fly ones are nice as you can choose what colour you want instead of just having black, although i think the fly ones are sold seperate, so the bearings and caps are sold as seperate items.....thus making the headset about £30/£40?
Trev also does the FSA Impact ones as i got one off him for the Proper  :daumenhoch:
zed4130
« Reply #12 on: April 28, 2008, 12:02 PM »
yep its a impact on my bike aswell rob  :4_17_5: nice and smooth  :daumenhoch:
evamedia
« Reply #13 on: April 28, 2008, 12:31 PM »
I also got an FSA off Trev for my Simple, been fine so far
Offline Gary72
« Reply #14 on: April 28, 2008, 01:39 PM »
Due to my impatience, tried the local bike shop, none in stock, but will have one in a couple of days, sorry Trev.
FSA Impact enroute
« Reply #15 on: April 28, 2008, 11:12 PM »
i got a spare in me garage gary lol
