975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 22, 2024, 02:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  pro class help *updated*again* now with pics
Author Topic: pro class help *updated*again* now with pics  (Read 4208 times)
Offline jimmyp
Re: pro class help *updated*again*
« Reply #25 on: April 29, 2008, 10:05 PM »
mmm a dificult one, just had a look at the super and the pro class rear dropouts again and both are 3mm. Everything about both  frames is just the same except the inside of the bottom bracket. Although i need to get the bb cups off and weigh both to see the true difference :-\
Offline kdw712
« Reply #26 on: April 29, 2008, 10:07 PM »
bloody mongoose ......  >:D
cheers Kev
« Reply #27 on: April 29, 2008, 10:09 PM »
We're 26 years or so too late to work this one out easily  :LolLolLolLol:
Offline jimmyp
« Reply #28 on: April 29, 2008, 10:11 PM »
Aghhh just had another look and if my life depended on it i would say the pro class rear dropouts are thinner but only just. The super is a defo 3mm where as the pro class is very slightly less by 000.05mm  :D
Offline kdw712
« Reply #29 on: April 29, 2008, 10:11 PM »
just found this in one of my sad bloke type spreadsheets
about my US spec supergoose
fork & frame     £110.00    apparent pro class
but weight is 2lb over test review figures   3.3kg   7.27lbs total combined weight
cheers Kev
Offline jimmyp
« Reply #30 on: April 29, 2008, 10:46 PM »
Lets have some pics of the box  :smitten: :shocked: :)
Offline AtariAger
« Reply #31 on: April 30, 2008, 03:16 AM »
I hate to bring it up but what about jimmyp's theory of the hole inside the bb from the seat tube? mine doesn't have that.
Also the weight thing..mine is the same weight overall as the pro class in the test but my frame weighs in heavier & the forks lighter than the test.
Any opinions?  :daumenhoch:
No worries...I have one of my Black Chrome frames hanging up right next to me...ONE hole coming from the downtube...no hole from seat tube.  So that theory is false...sorry jimmyp!   ;)
Also...the Pro Class is the only frame I have ever seen the b/b cup groove on.  Strikey...you can see it on your b/b and also in the picture I posted...another way of confirming a Pro Class.  The Super goose is flat all the way through.
Here is the inside shot of a Supergoose b/b...no ridge/groove
Offline AtariAger
« Reply #32 on: April 30, 2008, 03:19 AM »
Also...just measured the rear dropout thickness on the same Black Chrome frame...............
..........................2mm........................... :daumenhoch:
So there you go!
Pro Class... :smitten:
Offline Brandy Truffle
« Reply #33 on: April 30, 2008, 07:00 AM »
i've just stripped a survivor Pro Class complete bike i bought from a local paper,even got the original shop receipts with it so i know it's kosha....
I dont have scales to weigh frameset etc,but can tell you this one DOESNT have the hole Jimmy talks about, but DOES have cup grooves in the bottom bracket.
Would be interesting to compare some frame numbers close to Jimmys to see if that was the norm in production & likewise to one that doesnt.
Being an ex engineer,who specialised in batch built components,i can honestly say i think small details such as that would have inevitably varied along the course of a production run. All in the name of "continuous product development etc etc.." Especially in this case as the details mentioned would not have been externally visual and your average punter wouldnt notice/care at the time...
Save a group of investigating 30 something Old Schoolers nearly 25 years later!  :LolLolLolLol:
FuNMoNsTeR
« Reply #34 on: April 30, 2008, 07:04 PM »
Interesting thread....
 I bought this 'Pro Class' from a Rad Member a couple of months ago..... I have since had the original owner and restorer contact me thru eBay saying it is a SupergooseIII. When i asked who he sold it to he changed his mind.......said he had restored and sold on a SupergooseIII and a Pro Class and that the frameset i have is a Pro Class..... Have i had the wool pulled over my eyes???
 My frame weighs 4Lb 9ozs dry The rear dropouts are 2.5 mm thick. There is no seat tube hole in the BB shell and the BB is not stepped but smooth. Serial number is: H3001849
 Pictures: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320239495662
Offline jimmyp
« Reply #35 on: April 30, 2008, 08:03 PM »
I had the same frame offerd out to me and eventually declined it m8 cause i thought it was a supergoose 3 :-\. If tom is correct which i think he is then its a super3 :-[
Offline jimmyp
« Reply #36 on: April 30, 2008, 08:09 PM »
Just checked my Pro Class and the bottom bracket is the same with bb cup grove on. Looks like your ok strikey its a pro class :daumenhoch: nice one.
Wonder why some have an extra hole in the bb, i thought it was to save weight  :)
Offline kdw712
« Reply #37 on: May 01, 2008, 12:14 AM »
so the machined/stepped BB is the big clue then - cool add that to the knowledge bank  :daumenhoch:
cheers Kev
« Reply #38 on: May 01, 2008, 03:55 AM »
Usually its to aid heat dissippation & minimise distortion when welding 2 'tubes' together.
djgivvinup
« Reply #39 on: May 01, 2008, 08:16 AM »
There are a couple of things different on your 'Pro Class' frame & forks compared to mine...firstly the fork dropouts on mine have the slit to slide the axle into but then it goes into a circle at the top, where as the forks on yours just have a straight slit.(hope that makes sense?)
Secondly the bb is not stepped like you say, where as mine is..
Also the rear dropouts on mine are 2mm thick on mine & 2.5mm on yours..
It all seems very strange, but i'll leave to to Atari & jimmyp for the conclusion  :LolLolLolLol:
I'll get some pics up of mine shortly, cos i built it yesterday & i'll get some pics of that box for ya jimmyp  :daumenhoch:
djgivvinup
« Reply #40 on: May 01, 2008, 02:54 PM »
heres some pics of the complete bike with the box for the frameset..
I'm still looking for a couple of parts for it....180mm mongoose stamped opc & the proper takagi chainring to go on the power plate.   anyone got either part??  :daumenhoch:
Offline kdw712
Re: pro class help *updated*again* now with pics
« Reply #41 on: May 02, 2008, 06:19 AM »
very nice  :daumenhoch:
i can't believe that box though
& the fact that its survived for so long
cheers Kev
Offline AtariAger
« Reply #42 on: May 02, 2008, 06:31 AM »
Hey Strikey...did you purchase the Pro Class from HRD Racing...?   ???
djgivvinup
« Reply #43 on: May 02, 2008, 08:58 AM »
Yes mate i did buy it from HRD Racing, why do you ask?
Offline jimmyp
« Reply #44 on: May 02, 2008, 07:59 PM »
Who's HRD Racing  :-\ :-\
djgivvinup
« Reply #45 on: May 02, 2008, 08:06 PM »
This is were it all came from jimmyp....HRD Racing's for sale post a short while back..
http://www.radbmx.co.uk/forum/index.php'topic=60171.msg612615#msg612615
Offline AtariAger
« Reply #46 on: May 02, 2008, 08:43 PM »
I was just wondering who got a hold of it...when I saw the box it clicked.  You got it for a steal!  I had offered him double the price you paid while he was taking offers!  You must have sweet-talked him pretty good...LOL.
Offline jimmyp
« Reply #47 on: May 02, 2008, 09:23 PM »
mmm how much did it go for in the end  ;)
djgivvinup
« Reply #48 on: May 03, 2008, 09:11 AM »
after asking HRD for first dib dobs on the for sale post, i pm'd him & then gave him a call..had a bit of a chat about the bike & the other bits he had for sale then came to a price he was happy with.
After that i hassled the crap out of him to make sure the deal stayed intact  :LolLolLolLol:
He's a nice bloke....even nicer now i have his old Pro Class  :daumenhoch:
Can't tell ya what i paid for it jimmyp...i'd hate to see a grown man cry  :LolLolLolLol:  :LolLolLolLol:
