975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 09:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  MONGOOSE 3PC HOW CAN i USE SEALEAD BEARINGS WITH THIS AXLE?
Author Topic: MONGOOSE 3PC HOW CAN i USE SEALEAD BEARINGS WITH THIS AXLE?  (Read 634 times)
firebird4130
hI, i was wondering if anyone knows how I can use sealed cartridge bearings with this axle or if I can find a replacement axle that will allow me to do this, as this one is threaded like a one piece that uses the other type,
Thanks a lot.
HEYWOOD BMX
Re: MONGOOSE 3PC HOW CAN i USE SEALEAD BEARINGS WITH THIS AXLE?
« Reply #1 on: April 14, 2008, 11:15 PM »
 :) Looks like one of Mongoose`s low end cranks that came on the budget models.Probably would have had a caged open bearing b/b as well.Don`t know what kind of replacement axle would fit that though.
« Reply #2 on: April 14, 2008, 11:22 PM »
I have only ever seen open bearing bottom brackets for hexagonal axles before.
There is one on the bay at the moment which is open bearings.
http://cgi.ebay.co.uk/BMX-Bottom-Bracket-hexagonal_W0QQitemZ110242655409QQihZ001QQcategoryZ56193QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
« Reply #3 on: April 14, 2008, 11:28 PM »
Just had a thought! 4-Jeri cranks have hexagonal axles.  I know that the US bottom bracket for the 4-Jeri crank is open bearing, But the euro bottom bracket is sealed, so if you could get hold of a euro 4-Jeri bottom bracket you could then use a bottom bracket adapter to fit it in the frame.
It is a long way round but it would work.
« Last Edit: April 14, 2008, 11:31 PM by STIDDS »
