975755
TattooedYorkie
September 20, 2024, 05:20 AM
Chainring Problem.
Topic: Chainring Problem. (Read 728 times)
ligbee
Chainring Problem.
April 14, 2008, 08:22 PM »
Bought a couple of chainrings (Sugino/SR style) to which I was going to fit a standard Spider. When I tried to bolt the spider onto either of them, it seems that the spider is too small, is there two sizes of spider or is it a power disk fitting only.
Don't remember this problem back in the day.
ligbee.
crusty
Re: Chainring Problem.
April 14, 2008, 08:32 PM »
how much to small/big?
are you putting all 5 of the bolts in loose before you tighten any up there are a lot more knowledgable people on here that can help but this is all i can think of for now
ligbee
April 14, 2008, 08:34 PM »
You cannot as the pcd of the spider is too small, the radius of the holes could do with being about another 10 mm.
ligbee.
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
April 14, 2008, 08:35 PM »
i could be wrong but it sounds like you've got a Sugino spider and Takagi chainring? the Sugino spiders are smaller, thus there rings are bigger and the oposite for Takagi.
hope that makes sense?
ligbee
April 14, 2008, 08:37 PM »
That sounds about right.
I'll have to find out which one is which as both chainrings and spiders are copies.
ligbee
pickle
Site Supporter
My life is Radbmx
April 14, 2008, 08:39 PM »
yeah i did exactly the same mate, i had a sugino spider and then bought a Takagi chainring, you need a Sugino chainring mate
ligbee
April 14, 2008, 08:40 PM »
Cheers for that.
Thats why this site rules.
ligbee.
mark 2
April 14, 2008, 08:43 PM »
Well it sounds as if you got a 130mm bolt circle diameter chainring, something like a takagi, shimano or tioga (same thing) and a Sugino pattern spider which has a bcd of 110mm. You'll need either a Sugino, Suntour or Tuf Neck chainring to fit or get a powderdisc with the dual holes
Here's a 130mm
And these are 110mm
Hope that helps
***pickle answered while I was typing so it looks like I 've just copied him
Last Edit: April 14, 2008, 08:45 PM by mark j.
crusty
April 14, 2008, 08:44 PM »
i told you there be some smart people on 'ere
ligbee
April 14, 2008, 08:47 PM »
And just a click away as well.
Proper threw me out as I've never come across this before, just been lucky I suppose.
ligbee.
mark 2
April 14, 2008, 08:48 PM »
Quote from: crusty on April 14, 2008, 08:44 PM
Too much time on their hands more like
Chainring Problem.
