0 Members and 6 Guests are viewing this topic.
Hi, can anyone please tell me if you can spraypaint over sanded down powdercoat or if you need to remove it,Cheers
thanks for the reply dan, sorry but I'm just beginning with the bike spraying thing and not too sure what two pack is. Also can you tell me a good way of doing laquering coz you know I can't sometimes keep track of where I've laquered and where I've missed and sometimes it runs, is there a tip for getting it spot on?Cheers
you can get a good finish with canned laquer. just look at lazarous frame i did.easy process, spray the laquer on in fine coats, to avoid any running. you'll end up with quite a rough finish but eventually an even spread. then with 2000 grit wet and dry paper flat down the laquer to provide a smooth finish then polish with t-cut, or pretty much any other car polish to be honest.can't be asred to find the thread but it is titled 'is there no end to his talents' posted by lazarou about 3 weeks ago if you search for it
