975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 01:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing brake block marks from Tuffs
Author Topic: Removing brake block marks from Tuffs  (Read 658 times)
« on: March 31, 2008, 07:49 PM »
Nearly finished my Ammaco resto and about to fit on my green tuffs but after a closer inspection (they have been in storage for months), they have quite a few brake block marks on them, some quite dark. Is there any easy way of removing these? Thanks in advance,
Matt  :daumenhoch:
Offline Rombloke
  • do one
Re: Removing brake block marks from Tuffs
« Reply #1 on: March 31, 2008, 08:10 PM »
scrape the rims with a nice sharp stanley blade....scrape...not cut tho
Dave
haro, how do you do
dannywhiteley
« Reply #2 on: April 01, 2008, 02:04 PM »
I'd suggest a bit of really fine sandpaper and then buff up afterwards.
AxlFoley
« Reply #3 on: April 02, 2008, 11:10 AM »
what about wiping them with thinners, would it attack the plastic?
« Reply #4 on: April 02, 2008, 01:43 PM »
mount the wheel, (fnar) spin it, use a stanley blade as a lathe tool.
Offline HARORIDER
« Reply #5 on: April 02, 2008, 09:50 PM »
THE BEST THING TO REMOVE BRAKE BLOCK MARKS FROM TUFFS IS WITH FINE WET AND DRY PAPER DIPPED IN A SOLUTION OF WASHING UP LIQUID AND WATER ;)   YOU CAN ALSO APPLY THE SAME METHOD FOR MARKS ELSEWHERE ON THE WHEELS  :daumenhoch:
