975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:44 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  power disk & chain alignment - eh ?
Author Topic: power disk & chain alignment - eh ?  (Read 1933 times)
Offline kdw712
« on: December 21, 2005, 12:38 AM »
so xmas hols started today & i had some tinkering time  :santa_afro:
i began happily bolting bits on and then i tried to set up the rear wheel for the chain etc
i noticed it was rubbing the stay and that it also had a offset between freewheel and chain ring
oh crap !   :wtf:
so after a lot of fannying around the only solution is this ......
chain ring inside the power disk which looks pants frankly
so whats wrong ? i can't get the disk any nearer the BB or do i need to look at the free wheel end ?
or give up and buy a 43t tuf neck sprocket and bin power disk  :santa_cry:
help ............
cheers Kev
rakas17
Re: power disk & chain alignment - eh ?
« Reply #1 on: December 21, 2005, 07:44 AM »
dunno about solving your problem but i'm loving the pitbulll....  used to have one on my mid school bully piston.. :santa_afro:
« Last Edit: December 21, 2005, 08:40 AM by rakas17 »
Offline Bigplinky
« Reply #2 on: December 21, 2005, 08:01 AM »
Put a washer on the inside of the chainstays (one each side to keep the back wheel central) this will spread the rear triangle and give you clearance.
Andy
Offline kdw712
« Reply #3 on: December 21, 2005, 09:39 AM »
andy i have a washer on the freewheel side which has helped
guess the disk will have to stay that way  :santa_cry:
Rakas got the pitbull from cyclesport they are £6.50 along with the ACS boa's - bargain !  :santa_afro:
cheers Kev
Offline ORB
« Reply #4 on: December 21, 2005, 09:43 AM »
yeah, i build up the inside of the stay with washers when this problem occours.
12
Offline Waxintaxin
« Reply #5 on: December 21, 2005, 09:46 AM »
also kev , what sprocket (rear) are u using , i had loads of trouble with shimmano and using a suntour solved this prob
Rich
« Reply #6 on: December 21, 2005, 05:38 PM »
bang it with a hammer, but it looks fine how it is Kev
Offline kdw712
« Reply #7 on: December 21, 2005, 09:20 PM »
rich
not sure what free wheel is but chain ring is sugino,
bottom line is this - the power disk is where the chain ring should be  :-\
having ridden it today i may wanna lose the 180 cranks for 175 which will allow me to sort it once and for all
om that note :
any one know if flight 2 & monster crank arms share same size splined spindle at all
save me looking - lol  :LolLolLolLol:
Bob - top tip there, that was one idea i had last night with the poxy thing.
cheers Kev
rakas17
« Reply #8 on: December 22, 2005, 12:06 AM »
just ordered me a pitbull.... guess i'll have to start a new build to put it on.. bugger..
 cheers for the tip off..
« Reply #9 on: December 22, 2005, 12:01 PM »
i know that you have to run it that way on a gen 1 apparently. ask dave rombloke.
Offline Rombloke
  • do one
« Reply #10 on: December 22, 2005, 04:40 PM »
yip...other wise the chain fowls the seat stay....i actually preffered the look of it round this way though
Dave
haro, how do you do
