975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 10:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Polishing advice needed
Author Topic: Polishing advice needed  (Read 1003 times)
Offline Nosnod
« on: December 15, 2005, 09:54 AM »
Need some polishing advice guys
I have got a 6" bench grinder at home and I have been stripping a few parts and now want to start polishing some alloy cranks, stems etc. I have been looking about for the equipment and have a few questions:
1) Do the 6" mops fit straight onto the bench grinder axle or do I need something else as I have seen some tapered spindles for sale?
2) There appears to be a lot of different mops available such as sisal, calico etc and different compounds. Do I need all these or can I rationalise a bit (say 2 different ones). In what order should I use them
3) Do you just spread the polishing compound onto the part and then polish away!?
Cheers fellas  :santa_afro:
FuNMoNsTeR
Re: Polishing advice needed
« Reply #1 on: December 15, 2005, 11:16 AM »
Hi m8... thats a coincidence. Im trying to find info on this too :santa_grin:
 I think the mops are for use on a drill rather than a grinder but i may be wrong. I have had my eye on a set from ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8009954783&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
they do larger kits too.
cake video
« Reply #2 on: December 15, 2005, 11:36 AM »
put the paste onto the mop, not the part to be polished. not too much either, or it will clog your mop. if this happens a wire brush usually sorts it.
work your way through the grades of paste. tapered spindles help prevent the mop from slipping.
they are only material with leather reinforcement.
Offline sawzall
« Reply #3 on: December 15, 2005, 06:43 PM »
for mops polish etc try  www. thepolishingshop.co.uk i get all my polishing gear from here really cheap and good quality :santa_afro:
