975808
Robertflamn
November 26, 2024, 02:29 PM
Powder coat question for the Don
Topic: Powder coat question for the Don (Read 610 times)
muttley
February 22, 2008, 08:06 AM »
If you have a frame repair IE dent repair, i suppose its done using filler, but my my query is if you then have the frame powdercoated does that area still get coated or as its not metal will it not adhere
Ross.
superbikedan
BMX Legend
900 Air
Re: Powder coat question for the Don
February 22, 2008, 09:56 AM »
ross, you can't powder over body filler, what happens is that when the frame reaches
180degrees in heat in the oven, the filler goes soft and starts to bubble,
Trev
February 22, 2008, 09:59 AM »
looks like you're stuck with your spine trophy then Ross....
muttley
February 22, 2008, 10:05 AM »
DOH!!!!
Cant you turn the oven down a bit
sawzall
540 Air
February 22, 2008, 05:58 PM »
is it possible to powder over lead (body solder)
if not we have a tool at work that you can reverse pull dents out,most body shops should have one,i have done a couple of frames and bars with it with good results
lazychubs
Founding Fathers
BMX Nerd
February 22, 2008, 06:48 PM »
yeah ya need the weld on dent puller ross
