975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 10:39 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Enigineering firms in Essex
Author Topic: Enigineering firms in Essex  (Read 1175 times)
lloydieboy
« on: December 12, 2005, 07:09 PM »
Hi all,
does anyone know of a good engineering company in Essex? I want to have the drop outs widened on an old school fram so that i can fit new school wheels....
Lloyd
Donker
Re: Enigineering firms in Essex
« Reply #1 on: December 12, 2005, 07:43 PM »
yellow pages, or you could try the local college/uni if they have a machine shop and a technician/teacher/lecturer etc...
Offline Rombloke
  • do one
« Reply #2 on: December 12, 2005, 07:44 PM »
get a dremmel and do it yourself fella.....i used a dremmel on some forks and it ate through the chro mo in no time with the sanding drum attachment....b and qs do there own brand dremmel for around a score bloke
good luck
Dave
haro, how do you do
« Reply #3 on: December 13, 2005, 12:20 AM »
It can be done gently with an angle grinder.....  Get a couple of bits of heavy steel plate, 5mm or thicker and clamp them either side of the dropout in the appropriate position.  you can either take all the material out of the top or bottom (it doesn't ride any different) or equal amounts off both if you want to keep the axle dead-centre. Then gently grind way until you're touching all the way along your steel plate guide.  A little tidy up with a file and you're there.  Many, many riders have done this no worries. Just go easy is all..... :)
lloydieboy
« Reply #4 on: December 14, 2005, 03:02 PM »
Cheers for the suggestions guys. I'll get to it!
Lloyd
« Reply #5 on: December 14, 2005, 03:31 PM »
good advice from 2bobrob  :santa_afro:
harvey mushman
« Reply #6 on: December 27, 2005, 08:43 PM »
Llyodieboy
Give me a ring in the new year and I will do it for you.
Mark.( Carrie's fella).
Andy
« Reply #7 on: December 27, 2005, 08:48 PM »
Instead of all the above you could just file the axle of the wheel so its slotted it will then fit 10 or 14mm dropout frames
andy
« Reply #8 on: December 27, 2005, 08:49 PM »
you can buy axles like that. already done like.
Andy
« Reply #9 on: December 27, 2005, 08:51 PM »
depends on  what hubs you run, you cant with profile ss
