I tried a USB Capture card and hooking it up to my dvd recorder.I don't think it is macrovision due to the fact it doesn't pulse the brightness. It just seem to be swamped in the green color range as if its been turned right up.I'll try removing all the other hardware connected to my TV, incase that is messing it up and I'll try a few other things. All of my Old School Videos are in good condition. If I can get it copying okay then the conversions should be spot on.I think when it plays NTSC it converts it to PAL 60 so my TV recognises it okay but the DVD recorder doesn't quite like it.Have you converted any US (NTSC) Tapes?
Its called EasyCAP.The thing I don't get is that when I plug it into my TV which is a bit shitty, it works perfectly. If I recorded that image it would be spot on.When I connect it to my DVD recorder it then goes Incredible Hulk on me!!
