975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 07:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  brakes questions
Author Topic: brakes questions  (Read 1307 times)
motomagII
brakes questions
« on: December 12, 2005, 06:35 PM »
got a brake adaptor from caplier brakes to new school brakes put hombre on then tried to fit v brakes and they dont fit the holes are too small for the to slide onto the adaptor .are hombre and v brakes different fittings ?
Offline Rombloke
  • do one
Re: brakes questions
« Reply #1 on: December 12, 2005, 06:48 PM »
cos v brakes and u brakes are different size(see how i stated the obvious there)
Dave
haro, how do you do
motomagII
« Reply #2 on: December 12, 2005, 07:10 PM »
yeah i think i figured that .i think .i though they were same fitting .set up hombre on the front but doesnt work very well really .got v brake on rear and it is shit hot so was trying to put on front too .can u set adaptors for the v brake from calipers ?
Offline Rombloke
  • do one
« Reply #3 on: December 12, 2005, 07:41 PM »
i think you can get em gregg yeah...but to be honest, a u brake can be set up to work the boll0cks
never as good as a v brake , but there seems to be no in between with v brakes...they are either off...or on....try to fettle the ubrake...it will come good
good luck
Dave
haro, how do you do
motomagII
« Reply #4 on: December 12, 2005, 07:51 PM »
the u brake works fine until i u turn the cable then it seems crap .but it seems to be the only way to set it up .ie cable tie to forks and u back to caliper
Offline Rombloke
  • do one
« Reply #5 on: December 12, 2005, 07:57 PM »
lube the cable with silicone spray ....plenty of grease on the lugs too gregg...thats the key...
honest
Dave
haro, how do you do
motomagII
« Reply #6 on: December 12, 2005, 08:54 PM »
silicone spray .i sprayed wd 40 down them is this not good ?
Offline Rombloke
  • do one
« Reply #7 on: December 12, 2005, 10:13 PM »
no...funnily enough wd doesnt really lube well enough....common grease is miles better, but silicone spray is the best...you can get bike specific stuff from halfords...not dear at all mate
Dave
haro, how do you do
Offline ORB
« Reply #8 on: December 12, 2005, 10:30 PM »
WD40 is evil.
12
