975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 10:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Any tips on removing GRAB ON Grips then.....???
Author Topic: Any tips on removing GRAB ON Grips then.....???  (Read 1229 times)
Offline brass monkey!
« on: January 31, 2008, 04:19 PM »
I have a near NOS Pair of Grab On MX3's which I need to remove from a pair of Bars,
they're as tight as a nun's c**t, so how do I get em off ? they are not as pliable as rubber grips they may tear if i try to lodge a screwdriver inside em,
ANY TIPS !?! Please
thank you
Matt
Goose1
Re: Any tips on removing GRAB ON Grips then.....???
« Reply #1 on: January 31, 2008, 04:28 PM »
Can't you take the bars off and dip the grips in hot soapy water? They will become pliable and if you ease the soapy water under the grips they will slide off......it's a method I find works very well.
« Reply #2 on: January 31, 2008, 05:08 PM »
poke a spoke in there. once you have a bit of wd40 in the gap it will find it's way all around the grip
spesh
« Reply #3 on: January 31, 2008, 05:20 PM »
if youve got a set of long ball-end allen keys use a 2mm and slide it under the grip and squirt window cleaner (it evaporates unlike wd40) and twist the allen key in the grip and it will move the cleaner around the grip and pull it off   yeah baby!
« Reply #4 on: January 31, 2008, 05:57 PM »
Stanley knife  ;)
« Reply #5 on: January 31, 2008, 07:37 PM »
Stanley knife  ;)
Or a hammer, can;t go wrong with a big hammer  :daumenhoch:
« Reply #6 on: January 31, 2008, 07:41 PM »
Spray the red tube that comes with WD40, insert said tube into the gap between bar and grip, re-attach WD40 nozzle and spray as you penetrate. Waggleing at this point is said to aid lubrication. DONE  :daumenhoch:
steve Beech TA
« Reply #7 on: January 31, 2008, 08:09 PM »
Hammer is no good, a still saw works better.
Only joking washing up water looks good!
« Reply #8 on: January 31, 2008, 08:10 PM »
lOOKS lIKE i'LL bE gETTING tHE wASHING uP lIQUID oUTTA tHE cUPBOARD tHEN..... :)
Offline Rombloke
  • do one
« Reply #9 on: January 31, 2008, 10:05 PM »
air line.....blow em of
Dave
haro, how do you do
« Reply #10 on: January 31, 2008, 10:08 PM »
Dave
ive heard dave likes to blow off  :2funny:
daz bmx it!
« Reply #11 on: January 31, 2008, 11:16 PM »
Matt,send em to me I'll take em off for you and dispose of them ;) and send you the bars back :D
Offline Rombloke
  • do one
« Reply #12 on: February 01, 2008, 08:55 PM »
Dave
pot........kettle
haro, how do you do
« Reply #13 on: February 01, 2008, 09:33 PM »
Dave
pot........kettle
lol im a champion trumper me
Offline Zippy
« Reply #14 on: February 02, 2008, 01:46 PM »
Really easy way to take off grips is to get a footpump and popping it over the hole in the end of the grip and pump away. The grip expands and just slides off. So no more screwdrivers down the handlenars.  :LolLolLolLol:
« Reply #15 on: February 03, 2008, 01:21 PM »
You've got feckin Redtube on the brain
« Last Edit: February 03, 2008, 10:06 PM by Rom Bloke »
Offline Rombloke
  • do one
« Reply #16 on: February 03, 2008, 10:08 PM »
hunterdubber, was there any need to put links to porn on here.....seriously.
twat
Dave
haro, how do you do
