975886 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 18, 2025, 06:39 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Landing gear - threaded and bear trap 2 headset
Author Topic: Landing gear - threaded and bear trap 2 headset  (Read 617 times)
Boybaker30
« on: January 27, 2008, 06:49 PM »
I am struggling to fit a new Bear Trap 2 head set to my ripper, it has threaded LG forks but the bottom part of the headset seems loose aroung the forks and has a lot of play once its all put together.
Is there a shim that I am missing?
Will this combo work?
Have I just put it together wrong?
Re: Landing gear - threaded and bear trap 2 headset
« Reply #1 on: January 27, 2008, 06:56 PM »
Sounds like you need to put a couple of winds of electrical tape around the fork to pick up the slack.  There should be a brass shim on the forks but it sounds like that is missing, not unexpectd if they are old forks  :daumenhoch:
Boybaker30
« Reply #2 on: January 27, 2008, 07:01 PM »
Found the shim but it is still loose?
Will the tape do the trick?
Can you buy the brass shims?
Thanks for the help -  :daumenhoch:
Boybaker30
« Reply #3 on: January 27, 2008, 07:03 PM »
And I could alsways use the same colour electrical tape as the stuff that I peeled off the forks!!!!!!!!! :uglystupid2:
« Reply #4 on: January 27, 2008, 07:05 PM »
It always worked when I worked in a bike shop  :daumenhoch:
skids
« Reply #5 on: January 28, 2008, 09:09 AM »
If the tape does'nt work, cut a strip of metal out of a coke can, I found this makes-
a "no-give" substitute.
remember........it has to be real Cocoa Cola, or it will explode killing all around you!
 :LolLolLolLol:.............Skids
Boybaker30
« Reply #6 on: January 28, 2008, 01:34 PM »
Thanks for your help guys.
The coke can sounds a little easier than the baked bean tin somebody at work suggested, he said the same thing about them being HEINZ beans and people getting killed if a snide bean tin was used?
