this is bmx right ive seen cups literally fall into the shell when on its side and others that were simply the wrong size to use a lathe you need to know what size the shell is in the first place and once that calipers out i can guarantee no shell measured will be the same decent chrome will add no notable thickness and skimming it will have it flaking off and rusting the frame if anything more than hand tools are needed to pop some cups in then doesnt that say they are the wrong size id love to know do those peoples bearings spin freely or do they require a little "push" ( and thats without the cranks on ) if the cups are alloy get a file and take your time , if they are steel get measuring ( precision tools ) and if they are a close tolerance warm the shell
