975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 09:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxalyic Acid??
Author Topic: Oxalyic Acid??  (Read 4277 times)
lcfc
Oxalyic Acid??
« on: January 23, 2008, 02:12 AM »
  Right can anyone give me a dumb ass user guild as to what to ask for when entering B&Q in the UK.
  As all i seem to get is blank vacant you been tango'd looks and frowns.
  What else is it marketed under thats readily on sale in B&Q.
  Pics of the containers would be even better, thank you.
Offline kdw712
Re: Oxalyic Acid??
« Reply #1 on: January 23, 2008, 07:11 AM »
i think its also called wood bleach - but not 100% on that  :coolsmiley:
cheers Kev
Offline dwain dibbly
Re: Oxalyic Acid??
« Reply #2 on: January 23, 2008, 10:55 AM »
i had this conversation with munners (the oxalic king) last week.
i can get hold of wood bleach at our local timber yard but i don't think its the
same as oxalic.
the wood bleach comes in a liquid/gel for similar to paint stripper.
oxalic, im led to believe are granules that you dilute in water then leave the frame
to soak.
i believe oxalic is quite specialist and it may be a case of ordering online and
its pricey :shocked:
im going to to buy a small tin of wood bleach and give it a go.
 only need a small amount to get into the tight areas.
i will let you know how i get on :daumenhoch:
munners
Re: Oxalyic Acid??
« Reply #3 on: January 23, 2008, 10:59 AM »
same as oxalic.
to soak.
John. Save your money mate.
This is where to get it from.
http://www.agwoodcare.co.uk/show_product.php?id=106&gclid=CIOz5b6w-48CFQdEFQodK1iBLQ
Quick delivery. Pricey BUT if you get a pasterers bath for £20 and fill it with the acid and water you can keep it for ages if you put a plank of wood over it so that it dosent evaporate.  ;) If you lived local i would have done yours for ya for nothing!  ;)
Re: Oxalyic Acid??
« Reply #4 on: January 23, 2008, 11:04 AM »
same as oxalic.
to soak.
so how much would we need to do a frame?
munners
Re: Oxalyic Acid??
« Reply #5 on: January 23, 2008, 11:10 AM »
I always use the whole 5kg.
It doesn't hurt the frame and i always over do things!
This is probably why i have always got good results as i use 5kg.
Once it has been in the oxid for 2 days clean the area with the finest wire wall they do or use a very hard bristled tooth brush. ;)
Get it off, then clean the frame with fairy liquid and hot water. Polish it with autosol and spray the inside of the frame with wd40.
lcfc
Re: Oxalyic Acid??
« Reply #6 on: January 23, 2008, 01:14 PM »
  ??? i am still confused, does this mean that actually you cant go and buy it from B&Q or any other hardware retail outlet?
munners
Re: Oxalyic Acid??
« Reply #7 on: January 23, 2008, 01:16 PM »
never seen it there. only seen little bottles in timber merchants which are so small that they are pointless!
above link does the best i have used.
wildwood1971
Re: Oxalyic Acid??
« Reply #8 on: January 23, 2008, 02:33 PM »
totally agree with the above - save ya petrol money and get it online. The more you use the better and you get faster results - it wont touch stickers either. Just make sure you only use on steel and not alloy as it ruins it.
And as mentioned above spray plenty of WB40 into the frame after, as the frame will corrode from the inside out. :daumenhoch:
Offline Moose
Re: Oxalyic Acid??
« Reply #9 on: January 23, 2008, 03:20 PM »
I think I've seen it on ebay  :-\
wildwood1971
Re: Oxalyic Acid??
« Reply #10 on: January 23, 2008, 03:29 PM »
You have seen it on ebay  :daumenhoch:
lcfc
Re: Oxalyic Acid??
« Reply #11 on: January 24, 2008, 03:38 PM »
  http://constructionchemicals.co.uk/acatalog/joinery_products.html#a77
  Did alot of searching and found this, £15.50 ex. vat. for 5Kg of concentrate crystals, and delivered to your door next working day, total cost with delivery + vat = £24.03p.
  Best of all they are in my home City of Leicester and could have collected and reduced the cost only they had ran out and this is coming from their head office in Preston - along with another Ton of the stuff for themselves!!
Offline kuwahero
    • Western Titans
Re: Oxalyic Acid??
« Reply #12 on: January 24, 2008, 03:44 PM »
good find mate. loads cheaper than the other place we got it from. will keep a note of this one for future reference
marc
lcfc
Re: Oxalyic Acid??
« Reply #13 on: January 24, 2008, 04:05 PM »
  Right here we go, as they say.
  I intend to use and mix the stuff in a plasterer's bath and keep locked away with a sealed lid for future use, what is the ratio to use for basic rust lifting, i.e. 5kg of crystals should be added to what amount of water, i have read before that 10kgs is better but is that if you just want the job doing quicker or will 5kgs do just the same job but take a little longer?
  Also is there any stirring required or do you just leave it in the bath, walk away and return after a couple of days and jobs a good'un??
