975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 10:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spraying DIY
Author Topic: Spraying DIY  (Read 721 times)
Spraying DIY
« on: January 22, 2008, 03:55 PM »
Ok interested in having a go at this for my ultra burner bars which are being stripped right now. I'm going to spray these Gold but can anyone recommend the best way to approach this, what steps to take and also the best spray cans to purchase in Halfords?
Can's I've seen in halfords are:
* Hammerite Smooth Finish Metal Paint
* Plasti-kote Super Enamel
* Plasti-kote Fast Dry Enamel
Wasn't sure whether this Plasti-kote would stick well to the primer or not?
Any advice would be useful, thanks  :daumenhoch:
« Last Edit: January 22, 2008, 04:01 PM by Swivel »
Offline poolysheriff
Re: Spraying DIY
« Reply #1 on: January 22, 2008, 04:32 PM »
I have used Plasti-kote gloss on a frame n forks
Went on very well ,
I did use the primer first on the bare metal ,
I just sprayed it at my mates garage (hung up)
Sprayed it let it dry ,sprayed it let it dry etc
Till the tin was empty  :LolLolLolLol:
Don't spray too much on at once and make sure the frames not freezing cold either  :daumenhoch:
I will send you a pic of the 1 i did  ;)
Not bad at all for about a tenner  :LolLolLolLol:
Gary..
Offline dwain dibbly
Re: Spraying DIY
« Reply #2 on: January 22, 2008, 04:47 PM »
this time a year keep where your spraying warm.
primer, then 1200 or 1500grit wet flat,
 paint then wet flat again keep repeating paint and flat
until your happy.
remember though paint is the last step of a long process.
PREP IS EVERYTHING!!
spesh
Re: Spraying DIY
« Reply #3 on: January 22, 2008, 04:52 PM »
why not use halfords paint instead of plasticote as youve already primered it anyway
Re: Spraying DIY
« Reply #4 on: January 22, 2008, 04:57 PM »
Thanks for your tips here. The chrome is being stripped off the bars right now, then I need to rub them down and ensure all the nickel is gone and then start the priming process. I'll do the prime, then wet dry, then prime again and wet dry to ensure its really smooth and silky before I add on the plasti-kote paint. Gary, wouldn't mind seeing a photo of your frame and how that turned out dude  :daumenhoch:
bmx xxx
Re: Spraying DIY
« Reply #5 on: January 22, 2008, 05:08 PM »
i must admit for my lastest build which should be finished very soon,
i sprayed it over xmas, and normaly would have took it to the powder coaters and just picked it up a few days later
and thought no more of it,
i am glad i done the spaying looks the nuts,
prep is very important :daumenhoch:
if you mess up let it dry rub it down,
have a go, all the best
Re: Spraying DIY
« Reply #6 on: January 22, 2008, 05:10 PM »
i
i know its not a frame bit i did this bumper with rattle cans :shocked: :shocked: :shocked:
mind you it had about 3 weeks work in it :shocked: :shocked:
and by the time id finished it would have been just of cheap to get it done professionally :2funny:
Offline PHIPPSIO
Re: Spraying DIY
« Reply #7 on: January 22, 2008, 06:07 PM »
I have used standard automotive paints in the past. Just a case of getting enough coats on and as has been stated making sure you use wet and dry between each coat to ensure its even, no runs and the next coat can key to the abraded surface. I tend to finish with two coats of clear laquer which makes it shine like a proper job.
spesh
Re: Spraying DIY
« Reply #8 on: January 22, 2008, 07:24 PM »
heres my hoffman condor i sprayed with halfords rattle cans and it came out superb
a lot of prep and patience but woth it imo
Re: Spraying DIY
« Reply #9 on: January 22, 2008, 07:43 PM »
That is lovely mate! Ok i'm quite confident now that I won't fook up these bars, thanks for all your advice guys  :daumenhoch:
