975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Can you use a MX1000 caliper with a potts mod?
Author Topic: Can you use a MX1000 caliper with a potts mod?  (Read 755 times)
davevilla
« on: January 19, 2008, 04:33 PM »
Here's one for those experienced in freestyle setups...
Can you use a MX1000 front caliper in potts mod set up?
I was thinking of fitting a set of MX1000s to a StreetBeat that will be delivered shortly. I've just had a gander at the caliper I'm planning on fitting and it doesn't look like it is possible to  switch the brake fittings to make a potts mod work - am I wrong?
Any help or advice would be very gratefully received, cheers  :daumenhoch:
Re: Can you use a MX1000 caliper with a potts mod?
« Reply #1 on: January 19, 2008, 04:56 PM »
Yes it can be done, wait there & I will take a pic of how  :daumenhoch:
Ok I think this is the best way to do it, as you can return it to a standard front brake after if you need to, all you will need is another Wieman adjuster.
You can drill out the quick release & then just swap the bolt & the adjuster over, but I think this way is better.
« Last Edit: January 19, 2008, 05:19 PM by wish id kept my TA »
snav69
« Reply #2 on: January 19, 2008, 04:58 PM »
I've done it with some white ones on me haro master   :daumenhoch:
 :coolsmiley:
snav69
« Reply #3 on: January 19, 2008, 05:18 PM »
Nice one Chris  ;) here's mine  :)
I didn't keep my quick release though  :idiot2:
 :coolsmiley:
« Reply #4 on: January 19, 2008, 05:30 PM »
Thats the other way of doing it, your choice  ???
Great collection I can see there  :daumenhoch:
snav69
« Reply #5 on: January 19, 2008, 05:43 PM »
Cheers Chris  :daumenhoch: collection aint as big as it was though  :'(
greentoad
« Reply #6 on: January 19, 2008, 06:33 PM »
Hi all
This is how I remember it being done.
I always remember that the reason the quick release isn't used is because the cable is pulling from the other direction, and the forces can make the quick release open.  :shocked:
Chris, does that brake work okay, even doing endo's etc?
J.
davevilla
« Reply #7 on: January 19, 2008, 06:36 PM »
Great stuff lads...thanks for all the advice and pictures  :daumenhoch:
« Reply #8 on: January 19, 2008, 06:38 PM »
I had mine like that BITD & it worked fine for me, but I was only about 8 1/2 stone  :)
But my days of doing endows are well over, so I can't really answer truthfully, but if someone wants to try  :)
jackel
« Reply #9 on: January 19, 2008, 06:47 PM »
doesnt the top of the caliper stick up to much?clearance issues on certain bikes i know the  top of calipers way shorter on the 880s for this reason?
« Reply #10 on: January 19, 2008, 09:53 PM »
It is very close on my TA  :(
