975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Help needed installing a crown race to forks
Author Topic: Help needed installing a crown race to forks  (Read 659 times)
djgivvinup
« on: January 17, 2008, 07:22 PM »
i've just got my streetbeat back from superbike Dan after a superb paint job  :daumenhoch:  i've managed to install the bb cups & the headset cups without putting a single mark on the frame, but i've now come to fitting the crown race to the forks and i can't see any way to do it without risking marking the paint...Is there a way to install this without forking out(pardon the pun) for the expensive crown race tool?
Any help much appreciated  :daumenhoch:
Re: Help needed installing a crown race to forks
« Reply #1 on: January 17, 2008, 07:26 PM »
Wet and dry to take the edge off of it at the crown race on the forks to stop it chipping the powder coat and a short piece of scaffold tube to whack it onto the forks  :daumenhoch:
gossa
« Reply #2 on: January 17, 2008, 07:43 PM »
Depends on how tight/loose the fit is.  I took a BT2 crown race off of an elf fork today and it was not a tight fit.
If it's a snug fit you just need somthing to tap it down with, an oversized seatpost works well.
djgivvinup
« Reply #3 on: January 17, 2008, 07:57 PM »
Its a very tight fit....i think trying the wet n dry thing might be a good idea to start with  :daumenhoch:
Any other suggestions??
dibly
« Reply #4 on: January 17, 2008, 08:36 PM »
an over sized seat post idea works well but iv cut the end of an old ns peg and wacked it down the steerer fiited the race with out a mark
Dibly
Offline Rombloke
  • do one
« Reply #5 on: January 17, 2008, 08:38 PM »
halfords headset crown races are a loose fit on os bike...and only £3.99....try one
Dave
haro, how do you do
djgivvinup
« Reply #6 on: January 18, 2008, 08:47 AM »
Thanks for all the help guys...im gonna try the wet n dry on it today, see if i can make it fit a bit easier.  Then some sort of pole to hit it down with, if that doesn't work then i'll be making a visit to halfords to get another crown race  :daumenhoch:
Thanks again..
« Reply #7 on: January 18, 2008, 09:01 AM »
I just fitted a race to a set of old 1" forks and it was a right pain in the arse. I had to file down the top of the forks till the race went on, but I still had to smack it down with an ally tube and a big hammer. I had to take loads off the fork off before it fitted, but at least its a nice tight fit now. 1" headsets suck!
(oh, and it was a set of forks fresh back from SB Dan. I had to keep taking the race off again to file more fork off. One time I missed the race with the hammer and took a chunck of powder coat off!  :crazy2:. Dont tell Dan!  :police:)
« Reply #8 on: January 18, 2008, 10:17 AM »
a set of  new school forks fit nicely over the steerer tube of os forks.
djgivvinup
« Reply #9 on: January 19, 2008, 10:28 AM »
Finally managed to get the thing fitted  :D
I filed the forks down slightly where the crown race sits and wet n dried the race itself, it was still a tight fit, i didn't have any bloody tube to hit it down with & after an hour of trying to tap it down with a hammer & flat screwdriver, i found a spanner that fit around the race, sat it on top of the race & whacked it down a fair few times....five minutes later it was in place..woohooo!
Not a reccomended way of doing it but it did work  ;D
Thanks again to everyone who replied to this post its much appreciated  :daumenhoch:
