975755
TattooedYorkie
September 21, 2024, 09:23 PM
Freewheel removal – which tool?
Topic: Freewheel removal – which tool? (Read 457 times)
Stevo
January 07, 2008, 08:48 PM »
Guys, I would like remove this freewheel from a Haro Sport 06. Anyone know the manufacturer/model of the tool needed.
A supplier would be helpful too. Cheers
MartyC
Berm Worm
Re: Freewheel removal – which tool?
January 07, 2008, 09:01 PM »
It's a screw on lock ring, you should be able to get it off using a flat bladed screwdriver and a hammer, tap it anti-clockwise to undo. You can see the the mark close to the word "LOCK" where it's been tightened up using the same method
THIRSTYKIRSTY
January 07, 2008, 09:02 PM »
SAME AS ME CRUISER
ALL I DO IS GET A GOOD SCREW DRIVER
LEAVE WHEEL ON BIKE AND GET SOMEONE TO PUT FOOT ON PEDAL AND JUST CLOUT IT ANTICLOCKWISE
DOES THE JOB A TREAT
RUSS
Stevo
January 07, 2008, 09:12 PM »
Thanks guys, I did try it with a screw driver but it wouldn't budge. I will try again as it seems this is correct way to remove it. Cheers
subversion
January 07, 2008, 10:28 PM »
get yourself a C SPANNER from your local cycle/HW store
this will avoid damaging the lock ring....
2020mad
January 07, 2008, 10:57 PM »
Get a bigger hammer stevo
