975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 16, 2025, 08:29 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  CRANK ID HELP PLEASE!-now with photo
Author Topic: CRANK ID HELP PLEASE!-now with photo  (Read 1163 times)
HEYWOOD BMX
« on: January 02, 2008, 02:35 PM »
 :) Sorry no camera! I was given a set of crank arms today,may possibly Redlines.They are chrome and have 4 splines inside.The pedal and spindle bosses are full wrap and the single pinch bolt bosses are welded on.The drive side arm also has a "flange"where a spider would fit.The arms taper from box section at the spindle end to an oval at the pedal boss end.There is a machined channel on both sides of each arm,100mm x6 mm.All the Redline cranks that I have seen have Redline engraved in them,but these do not and have no decals.I have no spindle or b/b set.Could these be Redlines,and if so how much would they be worth? Sorry for the lack of photos but my camera has gone walkabout.
                Any help would be appreciated.
                        James
« Last Edit: January 02, 2008, 11:09 PM by HEYWOOD BMX »
snav69
Re: CRANK ID HELP PLEASE!
« Reply #1 on: January 02, 2008, 03:14 PM »
« Reply #2 on: January 02, 2008, 05:01 PM »
They sound like Peregrine cranks, pics would definitely help out  ;)
FuNMoNsTeR
« Reply #3 on: January 02, 2008, 05:56 PM »
Yeah they sound like Peregrines.... 4 spline :)
 Does the front face of the crank arm have two channels for decals...one longer than the other? If so then definately Peregrines.
dj_benice
« Reply #4 on: January 02, 2008, 06:07 PM »
Wasn't that the 2nd gen one, the first gen had single channel? Haven't the peregrines got capped off pedal bosses as well so you don't get crud on your pedal spindle?
FuNMoNsTeR
« Reply #5 on: January 02, 2008, 07:21 PM »
Like you say...the second gen have 2 channels and capped bosses... I am unsure of whether the first gen bosses are capped or not.
HEYWOOD BMX
« Reply #6 on: January 02, 2008, 09:37 PM »
 :) Thanks for the replies.Defo only 1 channel per side of each arm and 4 splines.I`ll try and find the camera again.Mine look closest to the `80s 401s but the boss for the chainring is longer.
« Last Edit: January 02, 2008, 09:43 PM by HEYWOOD BMX »
FuNMoNsTeR
« Reply #7 on: January 02, 2008, 10:33 PM »
Here is a shot of the second gen ones.
HEYWOOD BMX
« Reply #8 on: January 02, 2008, 11:05 PM »
 :) Thanks FunMoNSTER-mine are almost  the same,but have a single machined channel on each side of each arm.Any idea what they are???
« Last Edit: January 02, 2008, 11:15 PM by HEYWOOD BMX »
Re: CRANK ID HELP PLEASE!-now with photo
« Reply #9 on: January 02, 2008, 11:22 PM »
I reckon they are Peregrines, gen 1  :daumenhoch:
Someone here must have a pic of some they have or from a magazine  :-\.
Olliecw
« Reply #10 on: January 03, 2008, 05:28 PM »
Is it these ??? 1987 peregrine's
dj_benice
« Reply #11 on: January 03, 2008, 05:40 PM »
yup thems peregrines, got some decals for them somewhere ;)
« Reply #12 on: January 03, 2008, 05:43 PM »
Ollie, you are a star, like Pete says, they is deffo the same ones looking at the pedal and BB bosses  :daumenhoch:
HEYWOOD BMX
« Reply #13 on: January 03, 2008, 05:53 PM »
 :)Thanks again.Defo Peregrines then! What are these worth then(but I am not selling),as I maybe able to source a spindle and b/b set.....
« Last Edit: January 03, 2008, 05:59 PM by HEYWOOD BMX »
Olliecw
« Reply #14 on: January 03, 2008, 05:56 PM »
I can't see ya picture but it's sounds like these are the ones you have ;)
Ollie
