975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 04:44 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  pitbull brake
Author Topic: pitbull brake  (Read 739 times)
Offline Gary72
pitbull brake
« on: December 30, 2007, 11:35 PM »
just got one of these dont know if it's a 1 or 2, is it possible to strip and clean or re-paint, read some where about a brake with loads of bearings that fall out if you pull them apart, if anyone has any set-up diagrams that would be helpful too.
Seen some where a seat clamp with a built in cable guide thingy is that ness. or is that on a different version?????
cheers
Gary
Re: pitbull brake
« Reply #1 on: December 31, 2007, 10:59 AM »
sell it and get a real brake mate
Offline kdw712
Re: pitbull brake
« Reply #2 on: December 31, 2007, 11:13 AM »
Ignore the rat   ::)  :LolLolLolLol:
they're great brakes
the BOA has a million tiny ball bearings so your safe there
the mk 1 pitbull has a single bolt to mount on to a regular OS brake fitment
the seat post thing gets used a lot cos the PB is a centre cable route
bolt it on and use a decent cable and if you can a sprung lever
cheers Kev
Re: pitbull brake
« Reply #3 on: December 31, 2007, 11:22 AM »
the pitbull 2 fits exactly the same as a 1 but different design, when fitting it put a spring between the cam plate n the adjuster, this helps the brake return and feel smoother, ive done it to mt pitbull 1 and also on both these pitbull 2's
once you get the stretch outa the cable these brakes work amazin :daumenhoch:
« Last Edit: December 31, 2007, 11:26 AM by OrgasmDonor »
Offline Gary72
Re: pitbull brake
« Reply #4 on: December 31, 2007, 12:14 PM »
Cheers guys, cant see the pictures as I'm at work. Plan on using a new linear cable.
I always ignore the RAT. >:D
Offline kdw712
Re: pitbull brake
« Reply #5 on: December 31, 2007, 01:05 PM »
i got a slick linear cable as well
no stretchy-ness there
didn't know the 2's fitted the same way
not seen one up close
T1000's  :smitten:
i didn't use the cable locator that came with the brake prefered the posi stop
hence no spring for me  :(
thats the only weak point with PB's  the return of the cam after braking
make sure its clean and greased in its tracks
the springs will def help as would a sprung lever - all help it go back
these and BOAs are my fav OS brakes - cos they work  :daumenhoch:
cheers Kev
Offline Gary72
Re: pitbull brake
« Reply #6 on: January 07, 2008, 07:39 PM »
I need to get a spring, had trouble with the return when racing, a quick squirt of wd40 did the trick but it was muddy :LolLolLolLol:
Offline kdw712
Re: pitbull brake
« Reply #7 on: January 07, 2008, 10:02 PM »
LOL
think you may need a shock absorber spring in there  :shocked:
cheers Kev
