975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 10:03 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pro Neck question
Author Topic: Pro Neck question  (Read 545 times)
electro808
Pro Neck question
« on: December 26, 2007, 12:45 AM »
I've restored a few Tuf Necks but I've just bought a Pro Neck which I plan to strip and polish.  The great thing about Tuf Necks is the fact that, by undoing the large bolt, you can remove the quill which makes the stem really easy to polish.  I (carefully) tried to loosen the bolt on the Pro Neck so I could remove the quill but it is rock solid.  Is it possible to loosen that bolt on a pro Neck or is it fixed and just there for show?
Offline sawzall
Re: Pro Neck question
« Reply #1 on: December 26, 2007, 10:09 AM »
i have taken them off before,but i had to use a windy gun on it as it was tight as fook ;)
Offline Steve P
« Reply #2 on: December 26, 2007, 12:44 PM »
The Pro Neck is built exactly like the Tuf Neck ... I've restored two now and both main bolts came out easily
Try clamping an old seat post or bars in the stem to undo the main bolt ... use heat on the quill if required too  :daumenhoch:
Steve
« Reply #3 on: December 26, 2007, 12:45 PM »
yep mine come undone inc a helix one and copy one
DR VINOAH
« Reply #4 on: December 26, 2007, 05:03 PM »
steve is this the same bolt i cracked racing OS :angel:
electro808
« Reply #5 on: December 26, 2007, 05:48 PM »
Cool.  Thanks for the info.  I've Just polished this stem with the bolt and quill left in place but at least I know the score when I do another one...
Michael
Offline Steve P
« Reply #6 on: December 26, 2007, 10:52 PM »
It was Steve ... I'm still trying to work out how you managed to break one of those  :shocked:  :daumenhoch:
Steve
