975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  brakes
Author Topic: brakes  (Read 1049 times)
eloopnai
brakes
« on: December 09, 2007, 12:08 PM »
i have put my goose together and have a problem im not very good at expaining things so bear with me
 the rear brake pads only just sit on the rim of the skyways
if i shorten the chain anymore the freewheel touches the tubes on the dropouts so the wheels are sitting in the middle of the dropouts
ive put on the skyway tuff pads the thinner type not the blocks
and they are sitting as far out as poss in the brakes
so my question is how do i get the brake pads to sit more on the rims ?
it looks closer to the tyre in this pic than it actually is theres probally a couple of mill from the block sitting on the wheel to the tyre
or am i just being fussy and this is ok ?
Re: brakes
« Reply #1 on: December 09, 2007, 12:16 PM »
What brake are you using? Looks like a DC 901 and probably need something with 10cm of reach like an MX1000 or 1080 Shimano or DC brake.  Other thing to do might be to put some washers on your axle to spread the rear dropouts to give the freewheel some more clearance.
Marty  :daumenhoch:
Offline jT Racing
  • i like bikes. :/
Re: brakes
« Reply #2 on: December 09, 2007, 12:25 PM »
or use a smaller spacer between caliper and frame to move the brake up the wheel a tad.
ding dong
Re: brakes
« Reply #3 on: December 09, 2007, 12:29 PM »
Or get a half link for your chain  :daumenhoch:
Offline bodamus
Re: brakes
« Reply #4 on: December 09, 2007, 12:29 PM »
Yep what they said a Dia-compe 1020 or Shimano Tourney would give you a little more reach and would be a little more era correct if you were being fussy.
bodamus :)
Offline jT Racing
  • i like bikes. :/
Re: brakes
« Reply #5 on: December 09, 2007, 12:34 PM »
bodamus :)
LOL, didn't want to mention the era thing
ding dong
eloopnai
Re: brakes
« Reply #6 on: December 09, 2007, 12:54 PM »
thanks for the advice lads yep its a 901
 im not to fussy on the era thing as im gonna use it its not gonna be a show bike   :daumenhoch:
Offline phantom photon
Re: brakes
« Reply #7 on: December 09, 2007, 02:18 PM »
What he said  :daumenhoch:
Take out the 2 concave spacers that you've got fitted and stick them on the other side of the brake bracket on the frame. Will bring the caliper back a bit - just had to do the exact same thing on my DP with a set of 901's  ;)
eloopnai
Re: brakes
« Reply #8 on: December 09, 2007, 06:17 PM »
i did actually have the spacers behind to start with didnt make much difference
think im gonna try the shorter chain link think that will work just gotta get one from somewhere ?
 :daumenhoch: advice always appreciated fellas
eloopnai
Re: brakes
« Reply #10 on: December 09, 2007, 10:22 PM »
nice one  :daumenhoch:
