....If the wheels requires stripping (ie/the spokes taking out) there is a 5.00 change for this. IMPORTANT if you are stripping your own wheel YOU MUST REMOVE THE FREEWHEEL (if freewheel type) FIRST! If you do not do this we cannot get the freewheel off and we are all stuffed.
just do a quick relace with some wankey spokes and rim, its alot quicker
What an arse... gave a mate of mine who owns an Engineering company my set of Arayas from BITD to strip ano and polish,Rims great cond still,Bullseye Hubs virtually mint once i'd cleaned crap off them...I didnt have time to strip them,but in conversation he said,no worries,he'd get one of the lads who was doing the polishing to do it,asked if i wanted to keep spokes,i said no gonna rebuild...You can guess whats happened...... Geezer has snipped spokes off at the hubs and now i cant get the sprocket off....which means no re-useLooked for a bit of advice on wheelbuilding and saw ALANS build page here..http://www.alansbmx.com/wheelbuild.phpQuote....If the wheels requires stripping (ie/the spokes taking out) there is a 5.00 change for this. IMPORTANT if you are stripping your own wheel YOU MUST REMOVE THE FREEWHEEL (if freewheel type) FIRST! If you do not do this we cannot get the freewheel off and we are all stuffed. Any advice guys?
That is exactly the problem with the bullseyes, they are 3 piece
it's not difficult, you need an angle grinder, some masking tape, a vice, some wood and a cloth(not to mention goggles) use wood and cloth in vice to carefully grip your masked off hub(spray from grinder will mark any finish on said hub), with a thin(and i mean thin) cutting disk(you will need a few but they are cheap) proceed to cut through the cogs being carefull to not cut into the screw thread, or into the hub, and not in one go or it will get too hot and damage the finish. Experience and patience are important. use both hands on the grinder and use a 125mm grinder not a big stupid 230mm or something. I've done it twice now and it's a pain in the arse but it's nice to keep the hubs.
