975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 04:39 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  pedal pin grip things
Author Topic: pedal pin grip things  (Read 763 times)
Time Lord 1
« on: December 06, 2007, 11:31 PM »
hi, is there any replacement pin things for my custom m pedals, the little circle grip things??
Time Lord 1
Re: pedal pin grip things
« Reply #1 on: December 09, 2007, 08:57 PM »
anyone??? urgently need help
« Reply #2 on: December 09, 2007, 10:03 PM »
Stick a picture up buddy.  Are you talking about pins?
Time Lord 1
« Reply #3 on: December 09, 2007, 10:37 PM »
the little pins that are used for grip on pedals, they wear down or break off and i was wondering if they can be replaced and how
wildwood1971
« Reply #4 on: December 09, 2007, 10:46 PM »
theres a thread over on vintage - on how to restore DX's - its by ted carl but might be under who wants to learn to polish. Im sure he replaced the pins - might be what your after  :daumenhoch:
Paul
« Reply #5 on: December 09, 2007, 10:48 PM »
Righto.   Yeah, they can be replaced. For example, some are knurled and just press in, some are a little allen grub screw that screw in, you can buy them from a fixings company. As you can also buy a small allen headed bolt that screws in. Most are a regular metric thread.
If you want to replace the press in pin type things, best thing to do is get some roll pins. If you don't know what that is, a roll pin is made from spring steel and is a little hollow tube with a split in it all the way along its length. The idea is that you make the hole very slightly smaller than the pin, then drift the pin in. As its spring steel it will compress as its drifted in and then stay put.  They're a bastard to cut to length though.....
Or, you can use a length of solid bar from a model shop (2 or 3mm dia) cut down and superglue in   ;)
Time Lord 1
« Reply #6 on: December 10, 2007, 10:33 PM »
thanks for the help
