975822 Posts in 138946 Topics by 6374 Members - Latest Member: Boults December 26, 2024, 08:39 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Measuring tt and chainstay lengths...
Author Topic: Measuring tt and chainstay lengths...  (Read 678 times)
PaulM
« on: December 06, 2007, 02:13 PM »
When measuring tt and chainstay lengths where exactly are the measurements taken from,
I've got some frames I want to try and measure as im not sure of there sizes,
Paul
Offline se-bmxer
Re: Measuring tt and chainstay lengths...
« Reply #1 on: December 06, 2007, 02:18 PM »
Top tube measure from the center of the seatpost tube to the center of the headtube in a straight line alont the toptube
Chainstay is from the center of the BB tube to the middle of the rear drop outs (i think)
« Reply #2 on: December 06, 2007, 02:22 PM »
Like SE-Bmxers said: For TOP TUBE you would normaly measure along the top tube, from the center of the headtube to the center of the seat tube.
BUT: The problem is that if your frames have different seat angles, AND/OR,  if the top tubes are different heights (Modern frames  have very low top tubes that are at more of an angle than an older frames) you will get different measurements for what might actually be closer sized frames.
Can ... open ... worms ... everywhere
motomagII
« Reply #3 on: December 06, 2007, 02:51 PM »
no dont do it alex this has been done done and done to death but is correct ive ridden 21 top tubwe and now 19.5 top tube and they feel almost the same as headtube angle etc makes big difference
Offline sparky
« Reply #4 on: December 06, 2007, 02:52 PM »
Like this for the top tube from what I've always been advised :daumenhoch:
http://www.retrobsession.com/diamondback%20-%20measuring.html
« Reply #5 on: December 06, 2007, 03:10 PM »
Paul
[/quo
ffs...leave them alone, it took you a fooking day to choose what gloves to buy, and when you did they was shut
PaulM
« Reply #6 on: December 06, 2007, 07:15 PM »
Come on Pete leave it out, gutted I didnt get them gloves!
Cheers guys, very useful info.
So where frames differ in head tube and seat tube angles there length in tt and cs coulb be almost identical to another frame which has different tt and cs lengths? (if that makes sense)
Basically im thinking of going from a 20.8 tt and 14 cs to a frame with around a 20.5 tt and a 13.75 cs but with a lower standover height (shorter seat tube height)
I want a slightly shorter back end but not sure if the tt being slightly shorter would make much difference too (I used to ride a Mirra pro that had a 20.5 tt and 14 cs which I thought was ok)
Im a skinny 5' 10" tall if that makes much odds
Paul
« Reply #7 on: December 06, 2007, 10:33 PM »
You need to compare the wheelbases as well....
Are you sure you want a shorter back end for vert?
Offline Stodgy
    • RADBMX Shop
« Reply #8 on: December 06, 2007, 11:26 PM »
Ask Vicky, she'll know.
God knows you need all the help you can get... you were shite at the Masters.  ;)
