975806
V6 DOW
November 24, 2024, 06:58 PM
dropouts
Topic: dropouts (Read 479 times)
insideoutland
dropouts
November 25, 2007, 08:50 PM »
1 of my dropout is a bit bent
, any tips on straightening it out , also in the way of fixing the wheel the dropout has bent down 2-3mm which is stoping the axel going on
cheers phil
Last Edit: November 25, 2007, 09:43 PM by insideoutland
MartyC
Berm Worm
Re: dropouts
November 25, 2007, 10:27 PM »
Get a wrecking bar or "jimmy" as they are asl known as and gently prise the dropout open. Pics would be helpful to see ho far gone it is
insideoutland
Re: dropouts
November 25, 2007, 11:17 PM »
cheers dude , apart from the dropouts the frame is mint so its going to be worth sortin them out
MartyC
Berm Worm
Re: dropouts
November 25, 2007, 11:25 PM »
Minor bit of straigthening out with a pair of large adjustables to get the sideways kinks out. Looks like the dropout has been flattened a bit by the axle bolts but you should be able to open it just enough with a bit of gentle persuasion
insideoutland
Re: dropouts
November 25, 2007, 11:32 PM »
spot on
dropouts
