975808
V6 DOW
November 25, 2024, 08:21 PM
RIM HELP
Topic: RIM HELP (Read 757 times)
insideoutland
RIM HELP
November 18, 2007, 11:11 AM »
JUST PICKED THESE UP SER2 SER3 PRO CLASS
, JUST WANTED TO KNOW IF THE SER3 CAN BE CLEANED UP TO MATCH SER2 ,
I.E OVEN CLANER WET&DRY
ANY HELP WILL BE
CHEERS PHIL
Last Edit: November 18, 2007, 11:13 AM by insideoutland
MartyC
Berm Worm
Re: RIM HELP
November 18, 2007, 11:44 AM »
The dark rim is a hard anodised rim, not sure if it can be stripped in the same way, maybe Login_user or Atari_Ager can help as they are both Mongoose men
login_user
Re: RIM HELP
November 18, 2007, 01:08 PM »
Pm sent Mate, it can be stripped but it,will be harder then normal.
etriedes
Re: RIM HELP
November 18, 2007, 11:52 PM »
Caustic Soda, Thick Rubber Gloves, Mask, Eye Protection, and well ventilated area will do it
insideoutland
Re: RIM HELP
November 19, 2007, 12:28 AM »
AND AFTER THE C SODA
WILL THEY BE GOOD FOR A GOOD BUFF WITH SOME AUTO SOL??
sawzall
540 Air
Re: RIM HELP
November 21, 2007, 06:56 PM »
i did these which were hard anno pc3s, i stripped the anno using caustic which took ages to do,i just kept checking them to make sure they had'nt dissapeared then mirror polished them
insideoutland
Re: RIM HELP
November 22, 2007, 08:57 AM »
they look spot on dude
did you do the polish your self ?what best to use???
sawzall
540 Air
Re: RIM HELP
November 22, 2007, 06:45 PM »
yes mate i used a bench polishing mop,i use three stage polishing,from cource cutting compound,then medium and finish off with fine,they take a long time to do because of all the holes and you have to be careful not to loose any of the definition of the spoke holes etc
insideoutland
Re: RIM HELP
November 22, 2007, 10:31 PM »
cheers
RIM HELP
