975755
TattooedYorkie
September 23, 2024, 02:32 AM
Crank help. May be simple?
Topic: Crank help. May be simple? (Read 952 times)
munners
November 14, 2007, 07:44 AM »
Hi All,
Need help pretty urgently. My mrs has gone away and i have at last got the time to build my brother a Mongoose Cali that i had lying around.
I got hold of a NOS Takagi 170 op. The problem i have is that i am using a Sugino spider and Sugino chainring. The little arm on the crank arm that fits into the chainring is slighty lose once the crank is tightened so when you pedal you can feel some play. Its obviously wrong. It looks like the little arm is to small for the chainring hole.
Do i need to use a Takagi chainring and spider or a Sugino op?
Cheers everyone Nick.
munners
Re: Crank help. May be simple?
November 14, 2007, 09:28 AM »
Come on all... before she gets home!
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
November 14, 2007, 09:43 AM »
I'm no expert....but i think you might need a Takagi spider and chain ring? other than that i have no idea?!
i thought they were all the same diameter? and that it was just the length of the spider arms that were diferent between Takagi and Sugino?
munners
November 14, 2007, 09:46 AM »
Thats what i thought. However i have never seen a 170 Takagi opc only a 175? Reckon this is the reason? Ive got a Takagi spider but just need the chainring to see if this works.
Thanks Pick. From one CFC man to another!
pickle
Site Supporter
My life is Radbmx
November 14, 2007, 09:51 AM »
no worries.....try the Takagi spider......even without the chainring you should be able to see if it'll fit right
thebigdog
Look Back
November 15, 2007, 05:32 PM »
I am not sure what your saying here.
Takagi, sugino and nearly all 1 bit crank stuff should all interchange. Are you saying the locating pin on the crank arm is slopping about in the hole on the spider?
Is there loads of slop? The hole should be a lttle bigger to let the locating bit in and then you tighten the bearing cup thing up against it and it should hold it tight.
dan-dare
November 15, 2007, 05:39 PM »
Twill be fine with the sugino, mr.munners.
Yes the hole on the spider is slightly bigger, but once nipped up it'll be ok.
You are only pedalling forwards, so it will sit against the pin on the crank.
pickle
Site Supporter
My life is Radbmx
November 17, 2007, 08:42 AM »
i got the impression it was the main hole that the crank arm goes through that's bigger? not the small hole that stops the spider from spinning??
daz bmx it!
November 17, 2007, 03:55 PM »
I would go with the Takagi,thats what mongoose did bitd
you'll need the different chainwheel of course
SteveG
Curb Endo
November 17, 2007, 04:31 PM »
I think they are all a bit of a loose fit. I always had a bit of movement on mine as I had a coaster brake but it should be ok once the bearing cup is tight up against it.
TwoBobRob
Site Supporter
900 Air
November 17, 2007, 04:34 PM »
What he said
munners
Reply #11 on:
November 21, 2007, 08:41 AM »
Takagi spider and chainring solved it!
