975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 08:55 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  PROFILE EURO B/B/ HELP
Author Topic: PROFILE EURO B/B/ HELP  (Read 479 times)
HEYWOOD BMX
« on: November 01, 2007, 12:11 PM »
 :) Just got a new Euro Profile bottom bracket set.One side of the bearing cups has a groove machined into it.Please can someone tell me if this is for the drive/non-drive side,or if they are universal?
               Thanks,
                James
Offline diesel
Re: PROFILE EURO B/B/ HELP
« Reply #1 on: November 01, 2007, 12:14 PM »
Mechanic note: The puller tool pulls the arms on the spindle then tighten the crank arm bolts to finish the install. 3-pc cranks take 9/16" pedals. The treaded cups are right and left side. The drive side or also called sprocket side and tightens in a counterclockwise wise direction. These are real Profile cups and bearing so you can tell them apart. The drive side cup has a line engraved around the cup. The crank arm spacers are used to get your chain aligned with your freewheel and sprocket while allowing clearance from the chain stays on your frame.
HEYWOOD BMX
« Reply #2 on: November 01, 2007, 02:06 PM »
 :)Done-Cheers!!!!
