975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 03:47 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyway coaster
Author Topic: skyway coaster  (Read 471 times)
skyway coaster
« on: October 24, 2007, 03:20 PM »
i just built up a rear coaster hub suntour jobby
well the rear sprocket seems a bit sloppy not front to back but side to side  as in it jiggles like its not the correct size.
has anyone got one to hand to see if its tight   as i might have it not correctly assembled.
Offline JAY
Re: skyway coaster
« Reply #1 on: October 24, 2007, 03:54 PM »
Dan,if you have original sprocket and clip,they tend to be nice and tight with no play ,but you can get other sprockets and clips that fit fine other than they have play in which tends to be from side to side.I'm not sure if this will cause damage in the long run though ,as i've never used one for riding.Hope this is what you mean .......
Re: skyway coaster
« Reply #2 on: October 24, 2007, 03:59 PM »
yep jay its of a different coaster sprocket and clip  unknown brand  so will have to looky out for an original   :4_17_5:
i just fitted a rubber o ring gasket on and then the clip and its tight now.
