975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 06:56 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Flex Fighters Query
Author Topic: Flex Fighters Query  (Read 723 times)
Offline aerostylie
Flex Fighters Query
« on: October 08, 2007, 02:03 PM »
Hi folks. I might be answering my own question here, but are they designed to fit around the stem shaft ??? And are they worth buying, basically do they work?
Paul :)
Vans Style
Re: Flex Fighters Query
« Reply #1 on: October 08, 2007, 02:15 PM »
Yes, thats where they go .... no, they dont work!  :LolLolLolLol:
Always try and run your stem all the way down. If you want your grips higher, then use a "higher" stem or taller bars.
Offline aerostylie
« Reply #2 on: October 08, 2007, 06:01 PM »
Yeh I've always been told to run the stem all the way down, but me likes it a bit higher. Got some CW Pro bars that are tall enough but for my other bars, I think the flex fighter might possibly be the way to go......that extra inch makes all the difference  ;) :LolLolLolLol:
Vans Style
Offline generallee
« Reply #3 on: October 08, 2007, 06:29 PM »
i have a flexfighter for sale that would be perfect for you... pm sent!
« Reply #4 on: October 08, 2007, 09:01 PM »
The Hutch and early DK type 2in1 jobbies work quite well so long as you don't go for the really tall ones, I was never convinced about the Haro Flex Fighter, too thin to be really effective but the Hutch/DK type ones have a lot more meat on them and are screwed onto your forks in place of a headset top nut.  I ran a UK no-name one on my ELF and it worked Ok on that  :daumenhoch:.
« Reply #5 on: October 08, 2007, 09:05 PM »
You boys!!! You dont need your bars that high! What are you going to do when you finally move over to A-head! You cant jack a clamp on stem up 5 inches!!!  :LolLolLolLol:
« Reply #6 on: October 08, 2007, 09:14 PM »
« Reply #7 on: October 08, 2007, 09:27 PM »
this is the gospel.
