975755
TattooedYorkie
September 22, 2024, 02:33 AM
bmx burner id and value
Topic: bmx burner id and value (Read 493 times)
arcadejay
September 22, 2007, 12:47 PM »
i have a black burner with no markings on it i have pictures but do not know how to post pictures. i would like an id of the model and some sort of history of what type of model it was and how many made etc and a approx value
thanks jason
dj_benice
Re: bmx burner id and value
September 22, 2007, 12:50 PM »
there is a thread probably in help on how to post pictures probably a night burner at a guess with no pictures
some of the lads from the burner forum can probably tell ya more re value etc
othomas2
September 22, 2007, 11:20 PM »
Could be a night burner if if has a greyee tinge to it. More likely to be a black burner, with oval frame ??
Check
http://www.thrill.to/RaleighBurner
and you'll probably be able to verify what it may be from the catalogue pics.
If it's a standard burner which it sounds like it is (unless resprayed) then probably £100 ish if in reasonable cond. Obvisiously this is dependable.
Check
www.raleighburner.com
if you feel like it
I can be found there under the same name.
O
othomas2
September 22, 2007, 11:23 PM »
Also think you may have the wrong section... as this is primarily a pics only section.
Hopefully the mods can put it in a coool section of the site
