975753
TattooedYorkie
September 14, 2024, 05:37 PM
BMX General
BMX Chat
will a bench vice be anygood for pressing bearing cups in?
Topic: will a bench vice be anygood for pressing bearing cups in? (Read 806 times)
adenough
540 Air
Buzz Killington...
September 20, 2007, 04:23 PM »
MartyC
Berm Worm
Re: will a bench vice be anygood for pressing bearing cups in?
September 20, 2007, 06:26 PM »
If it opens wide enough and you can get some pieces of wood between the cups and the jaws then yep
wildwood1971
September 20, 2007, 06:48 PM »
Make sure you freeze the cups over night mate and put some washing up liquid on the edges before you put them in - freezing them slightly reduces the size and makes them sooooooooo much easier to fit.
Paul
September 20, 2007, 07:01 PM »
I dont really understand the question???
Is there any other way to put bearing cups in?
I just fitted a set of headset cups using a bench vice today. No freezing or lube involved at all (but I am crap at putting bikes together "well", even after all this time)
adenough
540 Air
Buzz Killington...
September 20, 2007, 07:54 PM »
Dark Diggler
Berm Worm
September 20, 2007, 08:02 PM »
3x2 plank, fookin big ammer and twat like tenmen.
Vice, next you will be saying that there are special tools for pressing headsets and bb cups.........proposterous
Dingobmxer
Founding Fathers
900 Air
September 20, 2007, 08:04 PM »
Heathens
DINGO
September 20, 2007, 08:08 PM »
what kind of headset and forks are they?
Dingobmxer
Founding Fathers
900 Air
September 20, 2007, 08:11 PM »
oops wrong pic
that was me facing the headtube so its square
is this better?
DINGO
September 20, 2007, 08:20 PM »
That seems a shame to go to so much effort for a cheap headset!
adenough
540 Air
Buzz Killington...
September 20, 2007, 08:22 PM »
nice bars, what make are they?
Dark Diggler
Berm Worm
Reply #11 on:
September 20, 2007, 08:26 PM »
Flatland them, bet he knocked in the bearings with a hammer and wood though
Dingobmxer
Founding Fathers
900 Air
Reply #12 on:
September 20, 2007, 08:27 PM »
Quote from: adenough on September 20, 2007, 08:22 PM
cant remember?
changed them now for something with a little more "sweep"
DINGO
Moose
540 Air
Reply #13 on:
September 20, 2007, 08:33 PM »
Don't forget the soft jaws, so that you don't damage those anodised headset cups
rarman1
Reply #14 on:
September 20, 2007, 10:43 PM »
Quote from: Dingobmxer on September 20, 2007, 08:04 PM
Heathens
DINGO
i recently made something like this with some threaded rod, 2 washers, 2 nuts and 2 3"x 3" 10mm plates which were offcuts from a metal works place around the corner to me, cost me £7 to make, let me know if you want me to post a pic and i'll take one tomorrow for you
oberonspacefruit
BMX Legend
Hoffman's Love Child
Reply #15 on:
September 20, 2007, 10:57 PM »
a vice works well. try to soften the blow to the cups though, with some wood or rubber or summat.
Gary72
Site Supporter
BMX Nerd
Reply #16 on:
September 20, 2007, 11:18 PM »
Have used the hydraulic press at work before
darkersomeday
Reply #17 on:
September 20, 2007, 11:29 PM »
the only thing to watch out for when using a vice for this is the axle alignment will be out and theres nothing to hold the spacer in place,
try pushing the cups in with the axle in place by swapping the vice from one side of the cup/bearing to the other, like 1 turn/squeeze on eack side,
good luck,
adenough
540 Air
Buzz Killington...
Reply #18 on:
September 20, 2007, 11:33 PM »
done it to my quality spec ( if it looks right, it is right)
BMX General
BMX Chat
