975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 07:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  rear drop out
Author Topic: rear drop out  (Read 517 times)
rear drop out
« on: September 16, 2007, 04:16 PM »
SHOCK  been in me attick today checkin on me stash . my se assasin has been damaged. rear wheel drop out has some how been bent inwards slightly. will a bit of rag to protect the paint and a pair of pliers will it bend back ok do you thing guys?
Offline sawzall
Re: rear drop out
« Reply #1 on: September 16, 2007, 04:20 PM »
if i were you i would put some masking tape,then rag on frame then some thin pieces of wood on both sides of drop out ,then use mole grips or pliers so if the jaws go through rag they wont scratch frame
darkersomeday
Re: rear drop out
« Reply #2 on: September 16, 2007, 05:28 PM »
thin layer of masking and a nice big adjustable spanner :daumenhoch:
you can adjust the jaws to hold the flat dropout properly while you tweak it back into position
